Sony Xperia XZ
daniel_83
I also bought 1, mine look like this
Sent from Sony F8332 using GAGT
Shinji_U
Guys, i found a rinkge clone on Aliexpress.
Ordered it already and waiting for delivery.
The rendering for the case is wrong. But the description for the XZ :s13:
Cross my fingers, will update again when i receive it
I bought the TPU case from P2O mobile, fit perfectly, with accurate cut outs etc. And doesn't pop out the newly installed tempered glass.
bigbadber
Help!
I plugged in my phone to my desktop windows 10.
but it doesnt show any icon for me to click to "safely remove device"
been wanting to ask this for some time, forgot about it.
my desktop is running windows 10 and i've installed Sony's PC companion,
after connecting my phone to my desktop, where do I click to safely remove hardware/device/phone?
I cant locate the option
Thanks.
see the above. bottom right hand corner
omelet
Help!
Sorry, not sure how to help you as it does appear on my windows 10 system.
Maybe it is inside the arrow icon? Or the remove device safely icon was set to hidden?
daniel_83
This screen protector looks good
Imak is a good brand
USD$7+, free shipping
Original Imak 3D surface full covered glass screen protective film for Sony Xperia XZ with retail package
http://www.aliexpress.com/item/32767516316/32767516316.html
(from AliExpress Android)
omelet
How do I use my XZ as a PS3 controller? I cant seem to set it up.
What do you mean by that? Are you trying to connect PS3 controller to your XZ? If that is the case, Sony had discontinued Dualshock 3 connection since Z3+.
You can however connect to the XZ with a PS4 controller. The XZ can also be used as a second screen or as a controller via remote play similar to the PSVita.
pandaren88
Anyone can SIC full cover screen protector? The one I got only has adhesive on the side, it looks damn ugly:(
