Digital TV (DVB T2) Consolidated thread III
jovially
Anyone staying at Sengkang?
Can recommend an antenna that is good and tested can receive the signal?
My understanding from a some one, SK may have a weak signal to receive all the channels. Thanks.
gregory_choo
It is a myth.
Why MDA want to give special treatment for sengkang?
noangel7
My PRC STB the K2 can't be switched on
Not sure whether remote or box problem.
Anyone knows how to on off the box without using the provided remote?
albertlee
The moment you on the power switch where the power adapter is connected to, the STB will turn on wat, there is no need to use remote control.
Highly possible the power adapter or worst the STB itself is up-lorry liao, use multi-meter to test if got output.
Note: Please replace the so-called "heatsink" use on the processor with a real one if you really want to prolong the "life" of the STB.
noangel7
The STB will 'on' into 'standby' mode with red indicator light when power switch is turned on.
To power on from standby mode, change channel etc need to use remote
Mine has red indicator light but pressing the remote has no response
Any idea how to link it to other remote? My Receiver has programmable remote but it doesn't detect the STB
albertlee
Shouldn't be if STB is working correctly, my unit will boot into "on" mode, which should be the way it function. Doesn't made sense to on TV and STB together and having to turn STB on again via remote.
Do you see the STB going thru the boot-up process?
noangel7
Thanks for that tip! power off and on the STB using mains power and indeed it boots straight to ON mode.
Tried to change channel using remote and failed so confirmed the remote spoilt.
Now... any tips how to change channel on the box directly?
Or have to pay $5.90 for new remote.
New box only $23.90 😑
albertlee
Is your box still under warranty? Can always contact your seller and see what can be done. That's provided he/she still around as some (like mine) has gone MIA or no longer selling this model of STB! :s22:
lo3xlo2x
Three options:
1) There is a remote control sale / repair shop in jurong point, approach them to find out cost
2) Buy from carousell. Cheapest that I found is $5.90
3) Buy another set top box and keep as spare. Ask seller to send extra remote for free / cheap.
EDIT: This may sound dumb, but have you tried changing the batteries?
jovially
I have shortlisted the following.
1) Funke Active 5.1
2) Daiyo EU 1702
3) Wavecom ANT-T25
Would like to hear the advise from the experts here who has experience on these antenna.
noangel7
Still around under different name.
box was bought 9 Dec 2015.
Have tried messaging seller!
noangel7
Three options:
1st thing I tried was change batteries 😅
Likely to go with (2) or (3) since (1) is east to west.
Good idea on asking seller for extra remote!
lerkaile
The salesperson at Best Denki told me I needed a box when I got my 65KU6000 and so I happily ponied up $49 for the Funke DSC550. Is that any good? :s13:
jovially
1) Funke Active 5.1
2) Daiyo EU 1702
3) Wavecom ANT-T25
Temporary using a power adapter as an antenna.
It works perfectly.
