ZTE Axon 7
siewmai or hargow
OK, I can update from recovery mode I have to enable OEM unlocking, but, I still can't update.
Anyways, can any programming sexpert tell moi what does this mean :
E: Error in /sideload/package.zip
(status 8)
Installation aborted
E is my SD card, but moi no money get another SD card leh
Sent from A Bottle Of Knee Gel using GAGT
idontknowdoyou
(status 8)
Exactly what versions are you trying to update from -> to?
If you're getting that error it sounds like you're trying to update from an unsupported firmware version or using the wrong firmware.
Get B05 from the ZTE website, then update with fota16 to B08.
Anything_Whatever
I think I have mentioned in my post above... IT has nothing to do with your micro SD card....
You can test by setting the camera saving folder to your micro-SD card and take some photos and videos.... then go there and see whether the photos and videos are OK or not..
idontknowdoyou
B05 cannot jump to B08, must be from B06 then can update to B08.
Imma install B03 before I start with b06
You can update from B05 to B08 with fota_B16 (800+MB). Unless your device stealth updated to B06 but is still showing B05 (unlikely).
From B06 to B08 you use fota_B19 (200+MB)
Dude, you have got to calm down and read our instructions carefully. That's probably why you're having so much trouble. You didn't even OEM unlock and those were the very first steps!!
And unless you bought a pirated SD card it probably has nothing to do with it.
siewmai or hargow
Changed the saving location to SD card, took a photo and a video, both were fine.
Anything_Whatever
So now we can confirm it's not your micro SD card issue.
I believed from previous postings, you have exchanged your original set before so this is your replacement set, rite?
.... And you are still facing problems, that would mean user problem.
Why can't you live with the working firmware ?:s8:
siewmai or hargow
Haha I'm the type that would wanna update if there's a update.
But if I can't update even if it's not compulsory, then that's a problem right?
siewmai or hargow
Yes this is the replacement set. I wished I didn't request for the replacement set when the solution was to do factory reset T.T
But well, I knew only after a few days after I got the replacement when the person helping me told me when I went to collect my VR headset
keltai
Hi Keltai, when I visited the Service Centre (Lor Chuan) on 22 Nov, the guy manning the Customer Service desk insisted they never released any firmware. Can you share some details of the person (look or name if possible) that you worked with 3 weeks ago?
I plan to visit and ask him again. Thanks.
Sorry, been bz with my moto z lately. a quite fit guy wearing spec updates e sw for me. he say e sw not released for ota yet... but so far so gd esp 4g beri fast and no lag
jkohlc2
saj282
Thanks. That sounds like the same guy who attended to me.
I am using B08 now and I think it is the best firmware. The responsiveness of the fingerprint scanner is now on par with the Nexus 6P I had used previously. And of course, the default presentation of notifications at Lock Screen is another boon.
Hope ZTE fixes/enables VoLTE on the phone soon.
saj282
Hi, has anyone tried using Samsung Gear S3 with the Axon 7?
Would appreciate if you can share your experiences. Thanks!
