Digital TV (DVB T2) Consolidated thread III
Tool18
Dear all , any idea if LG 49UH850T needs a converter plus antenna or just antenna for digital tv?
DarkAzure
Any recomendations on where can I get a good cheap and good Set top box + antenna at a good price?
Thanks.
wilflare
okie I'm a little lost... but do all TVs require an indoor antenna to receive the DVB-T2 signal?
PoloBoiBoi
so all the built-in antenna in our TVs are... "pointless" so to say?
is there such tv? :s11:
unless you are talking about built-in tuner, which is a totally different thing from antenna
albertlee
Made no sense to have antenna built on the TV itself. What happen if your area doesn't have good signal coverage, one would then need to move the TV instead of an antenna around in order to catch the signal! :s13:
wilflare
lol paiseh. don't know what I was typing last night.
I have a HU9000. it has a built-in tuner but for some reason still can't get the DVB-T2 signals - I think only got two rather scrambled indo channels
ekardo
no antenna ??
PoloBoiBoi
so u didnt connect antenna to the tv? :s11::s11::s11:
wilflare
no antenna ??
my bad guys. got really confused by the salesperson.
so just to confirm. even if my TV has a built-in DVB-T2 tuner, I would still need an indoor antenna regardless?
or can I use the cable point to get channels via DVB-C?
I was under the impression that I just have to run auto-tune and I should get it the channels (no need for any additional hardware whatsoever)
PoloBoiBoi
Yes, you will need an indoor antenna if you want to receive DVB-T2 channels
DVB-C? Not sure, but probably not
wilflare
are you distracted by the headlights . :D
thanks folks! I tried a DIY indoor antenna (basically, just ran the coaxial cable to the window) but the tuner still didn't catch anything... are tuners regional locked?
when mine is scanning, it runs through a list that says DTV Terrestrial 1, 2, 3, 4, etc... (I suppose it should be showing Channel 8, 5, Suria, etc) right?
