Xiaomi vacuum robot users lip lai please
chengsun
Can you comment on the run time? How long it can run after 1 full charge?
I saw on qoo10 the seller said 2.5 hours, but I doubt leh. So long?
My Neato can only last 45minutes. Even if Xiaomi can run only 1.5 hours, I think I will replace my Neato with Xiaomi.
furyoo
I don't know how long my Xiaomi lasts because it finishes the job in less than an hour.
It's highly efficient thanks to its smart mapping so it doesn't vacuum the same area twice and you can open the app to see its own mapping of the areas it went or didn't go.
chengsun
this is the part that i am very interested in.
furyoo
Short of showing you my house layout, I can tell you it works. The map will show in lines its movement, how it got around say chair legs, and because it uses a radar, it will indicate where it thinks the walls are. I used to keep my sliding doors slightly open only so it doesn't go into unwanted areas, it can detect the wall behind the door but you can see it was unable to reach it which is cool.
Buy the most basic set, then go Taobao and stock up on replacement parts just in case. Such as brush and the HEPA filter. For me I bought the virtual wall strip from Taobao to tape the toilet entrances and I can say it works.
adrianwang74
sounds good.
Shalomp
I stay in 2 storey landed and used to own a neato. The xiaomi is a thousand times better than the neato. Battery of the xiaomi is lithium ion and can vac my entire 2 stories with some power left. It also has intelligent mapping like neato. It has 3 levels of suction power while neato only got 1.
Oh and is half the price of a neato
AsusEpoxy
my xiaomi clears the whole flat cleanable area ~58sq meter in around 1 hour (not including kitchen), battery usually left 60+%.
Seriously, throw away the neato. overpriced and less capable
