Malaysia prepaid card
steven168z
3gb valid through out 28 mths? Until u used finish 3gb?
3gb is under season pass valid till yr sim card expire date
ALL season pass purchase expire will follow yr sim card validity
you can withdrawal bit by bit depend on yr usage.
this is what yr season pass look like
how much season pass data or mins you have will show below.. have 32GB season pass data
steven168z
yes, reactivate your number from
grace for rm1 and then follow by another 75 days of grace.
just rm5 and you get to keep your number for one year. not for the forgetful type though :)
reactivate your number from grace for rm1 and then follow by another 75 days of grace.
how to do it?
you mean topup rm1?
i thought reload voucher rm5 min for Digi
kitkat2
how to do it?
you mean topup rm1?
not topup but burn your credit balance.
when in grace, dial *128# and you will see the offer.
i remember boonkang has given a full illustration here before.
ONEXOX DEALER
onexox malaysia sim card
hi, i'm going up to kl for trip. if anyone would know. which prepaid card is best. i need free incoming calls. anyone can help? i tried surfing their celcom, maxis website. all no enough details lei....
Whatsapp me
8155 8133
steven168z
50mb if you buy the wrong data bundle.
pokemon plan is all the rage in malaysia now. rm1 gives you 300mb for 24 hours, and for that rm1 spent, you get to redeem 200mb valid for 7 days.
so it also mean rm1 get 500mb data for 1 day?
steven168z
so each time dial *128#, it will extend 75days from the date you dial or the from the existing end grace date ?
when dial *128# on that day, that day can use and the follow day will be start of 1st day of grace period?
kitkat2
you pay rm1 from your account balance to reactivate your number for 1 day. what comes after that? 75 days of grace period follows right?
*128# is the main menu. if you are eligible, you will get the offer to reactivate. dialling *128# does not extend your number.
Oinkize
Look out for Service Line, in Malay
The spelling is pretty similar to English
Either option 5 or 6 in *100#
By the way, I was told the menu can only be changed in home network
Not during roaming
That's not true. I used keypress to find the change language option via ussd.
That is how i can provide you with the steps...
kitkat2
when you use your hotlink outside malaysia, the telco is so intelligent that it will present you with a roaming menu instead the regular *100# menu.
you need to go to the end of the list and select 9 or 8 when in singapore, before you can get to the actual menu.
after that, it's 6, 1, 3 if i remember correctly.
a better way is to tweet customer service and ask them to change for you. you also need them to disable voicemail and caller ringtone or your credits will start disappearing.
Oinkize
Yup, 1st page of *100# is the roaming page, need to press 01 to go to next page to have the *100# option.
From there it will be as per in malaysia.
Good tip about vm and caller ringtone. Thank you.
boonkang
how to do it?
you mean topup rm1?
Bro steven168z,
You may wish to refer to a post I made in this thread less than 5 days ago -- see this link: http://forums.hardwarezone.com.sg/105438901-post4485.html
vaxvms
very detail explanation
steven168z
same lah the app shack....top up already use *132*1*pin# method to trsf to prepaid
the app cannot use pin voucher so jialat. sometime need to topup when the simcard are not with you.
web portial cannot use reload voucher to topup too and overseas credit card for topup.
have to use epay to buy and sometime if fail no other choice.
Tron portal can use reload voucher and paypal.
Daffy7
i think I just kena conned to buy hotlink fast 3.0... Anyone can share more details on this?
