stillgottheblues
- Dec 31, 2011
Every phone looks like iPhone and Apple computer just because we are brain washed by every articles out there through a long period of time.
Official update is coming soon. No need for all the trouble at this stage.
I don't even know if I'm on the correct Singapore firmware. It's a L19C900B190. I've some friends in SG whose phone is C636. Idk why mine is c900 haha. Would the update come to mine too?
u are on c900 cos u cross flash wrong.. because of this. jus cross flash over using the links i gave u.
i did it already.. word of advise.. read thru fully first before doing it and always factory reset after every update.
Yeah, just read through fully. Have since rooted my phone and did oemflash. Haven't updated to nougat yet, finding the L19 firmware. The guide is showing L09.
For user Huawei Updater tool:
In the Advanced/Custom ROM/Custom ROM version field, paste: EVA-L19C636B361
Custom ROM URL field: http://update.hicloud.com:8180/TDS/data/files/p3/s15/G1256/g104/v73917/f1/
1. Install Huawei HiSuite
2. Download Huawei Updater 2.0
3. Connect phone to PC, open HiSuite y established connection Hisuite <--> Phone (minimize HiSuite window)
--> Not connect?, touch "Settings - Advanced Settings -> Security" and enable "Allow HiSuite HDB"
4. Run Huawei Updater, chek the box "Custom ROM" and "Custom Port"
5. In box "Custom ROM Version" enter correct ROM version for flashing (example: EVA-L09C432B361)
6. In box "Custom ROM URL" enter correct ROM URL version for flashing (example: http://update.hicloud.com:8180/TDS/data/files/p3/s15/G753/g104/v73574/f1/)
7. Click on "Start" button and accept waiting alert messages
8. Maximize HiSuite windows, touch on "Settings" --> "General" --> Custom Proxy and configure using:
Address: 127.0.0.1
Port: 41279
9. Back to main HiSuite windows and click on "System update"
10. Press "Update" and wait download firmware. This smartphone reboot and start upgrade!
Try taobao? Got mine(Mate 9) from taobao. No air bubble no gap. Cover perfectly. But have to apply the oil provided. Tiagong will spoil ur screen if never apply properly and let it seep thru the glass.
Sent from HUAWEI MHA-L29 using GAGT
I think mate9 one no issue. But p9 ones seems to be either with gap or air bubbles
Sent from HUAWEI EVA-L19 using GAGT
Yeah I did all the steps, flashed everything correctly. Some others online have the same problem too. I rolled back and re rooted. Currently running a custom ROM and everything is working great. But thanks to you I now know how to change firmwares properly. Thanks again.
Thanks, the iqshield looks like screen protector than tempered glass. Are you using that? No air bubbles?
