[Maylyn - Networking] ASUS ROG Rapture GT-AC5300
ptey
Is the firmware working fine?
Decided not to connect to Singtel fibre. Waiting for M1 to come install the ONT and will connect to M1 instead. Thanks.
So in this case which firmware I should install?
wolnavi
Hey just curious, what is the difference between this model and the rt-ac5300?
Only noticed that this has 4 more lan ports and the "rubber ring"...
renfred89
you can continue to use the beta firmware, nothing will be enhanced for use on m1 though... haha..
renfred89
GT-AC5300 has gaming software to optimise gameplay on LAN in which traffic for gameplay is optimised over other priorities.. RT-AC5300 is just a normal router with WTFast client only.
wolnavi
I see, ok thanks
Might wanna sell my rt-ac5300 for this hahaha
Singapore21
Faster processor too. Boot up is very fast.
Lemon Porter
Can this GT-AC5300 router work on Starhub 1gbps fibre?
Intend to switch from Starhub Dlink 868L router.
badsector
speed test GT-AC5300 vs RT-AC5300 vs BRT-AC828 would be interesting
maylyn
ASUS ROG Rapture GT-AC5300 Firmware version 3.0.0.4.382.10397 ~ 06/04/2017
Security
- Change the password verification mechanism
- Establish a mechanism to prevent an attacker trying to login device
- Openssl enable AES256-SHA cipher
- fixed XXS, Session Stealing related issues. (Thanks to Eric Sauvageau)
Bug Fix
- Fix Download Master cannot be loaded after install
- Fix couple GUI issues
- Fix memory leak issue
- Fix few compatibility issues
- Fix few issues related with IPTV
Modify
- Add options of LAN port 5/6 for VLAN utilization
- System stability improvement
- Update AiProtection module
- Download master version update.
Please unzip the firmware file first then check the MD5 code.
MD5: B035E4CDDC26F35E18A6C93B70BD4C33
Download ~> http://dlcdnet.asus.com/pub/ASUS/wireless/GT-AC5300/FW_GT_AC5300_300438210397.zip
ntec66
no prob, from 868L to this is like night and day! :s13:
Dlink Dir-868L is fast enough for most users, few client devices can reach even 867 Mbps.
This is another over-hyped router from Asus waiting for users to beta test it.
renfred89
i think you mean above 867mbps bah.
so many devices floating in market supporting 867mbps...
ultimacloud
Just curious.
How does the SPI for this router compare to standalone firewall equipment in Juniper SSG and SRX series ?
And could it support VLAN tagging ?
KoBe_4EvEr
I am having problem with my GT-AC5300.
on Singtel Mio Fibre 1G plan.
Lan internet is okay. Once i start using WIFI with my I7/Samsung tab s, the router will reboot itself as seen from the Front status LEDs. After rebooting , my Wifi SSID will not be detected by my I7 or Samsung tab. Using Lan 1 as my IPTV port.
Added: Using the latest 10397 firmware.
Any help is appreciated.
No issue on my side. Did you use the link provided by maylyn or check firmware from the router itself?
