[OFFICIAL] Final Fantasy Brave Exvius - Part 2
Pegasus _1
Ok...
I was keeping DEF and SPR debuffed for the boss so I cannot see this point.
I see it now.
This time I lasted only 5 turns, chipping off only 10% of his HP.
Awfully clear that I don't know how to play this game :p
Better not sink anymore money into it.
A WOL is a must to debuff his atk/mag when ever he change his immunity. Dont do any debuff on his def/spr.
A healer who can heal and clear ailments…
The rest are physical or magical or mixed DPS to shred his HP down
Pegasus _1
Moi ASK friend more imba, he use 2x A2 and 2x 2B cum a friend A2 and he can clear in just 3 turn WTF. :(
This time the ELT they really tailor for those super whale to grind one. :(
He can clear ELT in 3 turns with A2 and 2B when the boss is magical immunity ba?
Cos i managed to clear ELT with normal ice queens in 4 turns when the boss is physical immunity…
bonkeng
I'm able to 2TKO ELT consistently now. Team setupis FV, DV, Orlandu, Fryevia, Fryevia. friend can be Fryevia or DV/Landu. FV can be replaced by enhanced Soleil as well.
1st turn: FV Defensive Barrier (or Soleil Def Dance), DV, Abyss Guard, Orlandu Crush Weapon, rest defend.
2nd turn: FV Inspire (or Soleil Atk Dance), rest chain. Def or Spr down won't matter.
Spr down
Def down
iron2000
I'm getting the hang of watching the immunity in PRO, but I don't think I have the DPS you guys have to hit hard enough to survive the boss in ELT.
I have an ok WoL, but still yet to raise a suitable healer for this kind of situation.
Remless
My bro got lucky and get CG Nichol from daily 250 lapis pull.
Really king of buffer now. If he is paired with a unit with party stat debuff resist, he can buff whole party for 130% stat in one turn.
Double cast spells and 阵 skills with ready to use mitigation shield and burst mp heal. Also have 70% element resist skills for 4 elements and counters with all element shield when attacked.
Best part is his buffs does not lock party in 12 weapon fights since they are not considered singing.
The only thing he does not do as a support char is debuff/breaks. CG lid still queen of debuff.
So far...
Cg sakura = broken mage
Cg Fina = broken healer
Cg lid = broken debuffer
Cg Nichol = broken buffer
Cg Lasswell = decent attacker
Cg Jake = decent finisher
Cg rain = ?????
iron2000
Got any story behind their upgrade to the CG forms?
I thought in story Rain is like not with the party, missing or something.
twtan14
Managed to reduce the Elite raid to just 8 turns but this raid is just so tedious for me.
iron2000
Tried ELT one more time.
This time is 11 turns got it down to 27%
At this point then the raid coins gotten is better than PRO.
This ELT is really too tedious unless your team are gods :p
Around turn 4 my healer died.
Around turn 8 or so my dual Ashe die one after another.
Final survivors are A2 then WoL.
Found a Fryevia friend with 1045 MAG, didn't field my own Fryevia as her stats sucks.
Would it help if a lousy Fryevia chain with a powerful Fryevia?
kinyat
My team to beat shadow Lord elt. Agrias, firion, wol, luka and zargabaath with a powerful friend(will also choose physical dmg).
1St Turn buff, luka reagen, wol debuff atk and mag, zar boost stats one by one. Rest normal atk.
2ND turn, need to see he blind or silence my team. Blind, he is weak to mag. Silence, he is weak to physical atk. Mag weak, I only normal atk and cure hp. Physical weak, I chain divine with mirage on wol equip pod153 and end with firion. Mag weak should win on turn 6. Physical weak will win on turn 7. My best unit only agrias at 655 atk.
Edit, I will not debuff it Def. Cos I notice it will go crazy. Hitting my wol with 5k dmg.
bonkeng
A lousy Fryevia is immensely helpful to a BiS Fryevia as both can elemental chain with each other. You could clear ELT in 3 turns if Shadowlord debuffs spr with 2 Fryevia. If you have enhanced Firion, stack all atk gears on him as well as Demon Killers and Man Eaters so you can also deal insane damage when Shadowlord debuffs def instead. With a team of WoL (arms eraser), Soleil (def and atk dance), Firion (fin briar finisher), A2, Fry and friend Fry, you should be able to clear ELT in 3 turns regardless of def or spr debuff.
iron2000
Hmm, will try fielding my Fryevia next time.
No enhanced Firion, Demon Killers or Man Eaters.
My Soleil still 4* lvl 46 not ready for primetime :p
coolmyth
Got Sice and Guy from free, daily gave me Mustadio.
Now that got dailies, maybe I should save lapis and refrain from doing dailies. Lately feel like no luck at all.
For the raid, if heng, can do in 3 turns, suay, will drag until turn 7. :s13:
iron2000
Tried using my Fryevia with the 1045 MAG Fryevia friend, really got use! Lucky turn 2 boss lower SPR then got it down to 50%.
But sad thing is I forgot to replenish the debuff so I was KOed a few turns later but got it down to 13%.
Notice another thing while I playing PRO.
At turn 6 the boss just go away and let me 'win'. Same pattern as Mog King.
