Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 3
Hailgod
why reccomend a ryzen over an intel for a gaming pc when they clearly perform worse in tests all over the internet.
5star_pundit
hoot some pc components from amazon now undecided whether I should water cool or not :
AMD Ryzen 7 1700X
MSI B350 Tomahawk Arctic
MSI Nvidia GTX1080 Gaming X Edition
Adata xpg spectrix d40 2400mhz 2x8gb
Sharp 32" living room TV
Samsung 950 Pro 512gb + WD Black NVMe 512Gb
be Quiet Dark Base Pro 900
Enermax Platimax DF Platinum 1200w
Edifier S1000db
Windows 10
ZrE0_Cha0s
AMD Ryzen 7 1700X
Edifier S1000db
Windows 10
if u intend to do high lvl OC den get a WC, if not doing high OC den air cooler should be fine.
-Synchronicity-
Yep. Intel is a better performer. Ryzen 5 1600 is around 90% of the performance at about 30% cheaper. Also i suggested waiting for coffeelake which isnt out yet. Check out the video below
https://m.youtube.com/watch?v=t8K2yc11eC4
Shearer1
Hi
Upgrading my PC from Intel i7-4771k ~2014, DDR3 16 gig.
Keeping my EVGA GTX 1080 FTW and ASUS PG279Q Monitor, Corsair H100i Cooler, and RM850 PSU
Thinking of:
SSD: Samsung 960 Pro M.2 512 gb
CPU: 7700K or wait for Coffee Lake
MOBO: ?
RAM: ?
Casing: ?
Speakers (Optional but pref good quality at decent price, say 1-200)
Assuming budget is okay but not too out of whack. Any suggestions?
ZrE0_Cha0s
Hi
Thinking of:
MOBO: ?
RAM: ?
Casing: ?
but tbh ur pc is still quite capable of handling current games, and if u still end up wanna to upgrade, i still think u should keep waiting for kopileg.
Shearer1
I agree with you. just itchy to squeeze out 20~% more frames on ultra 1440p AAA games. kopileg seems good tho.
lalawhee
Hi All
Looking to upgrade my current rig:
CPU: Intel Core i7-4790
MB: ASRock B85M Pro4
RAM: Kingston PC1600 DDR3 8GB X2
GPU: Zotac GTX 960 2GB Twin Fan OC
SSD: Samsung SSD 850 EVO 250GB
HDD: Seagate 3.5" 4TB SATA3 HDD
ODD: Samsung 24X CD/DVD Writer
PSU: Seasonic S12G 450W [80 Plus Gold]
Looking to upgrade also because of a persistent problem:
My desktop keeps restarting on it's own.
Sometimes it can last me quite awhile, after a half/an hour usage it will restart.
Once the restart kicks in, it will keep restarting after the log in. Its a cycle loop. log in restart, log in restart.
Only after i off it for sometime then it can last me another half/an hour again.
I also realised if i watch videos, some files will restart immediately.
I check my temperature and fan, all is fine.
Any advice anyone?
ZrE0_Cha0s
Hi All
Any advice anyone?
well for your system i still think that the cpu is overkill for your usage, unless u are really playing for high end gpu games do consider upgrading your gpu.
but to solve your issues, my guess will be either your mobo, psu or rams.
if your system is still under warranty, u can send it down for testing, but if its now u can consider going down to SLS to have a check. and see if mobo is it required to change or not. but please do ask if they still have haswell chipset board as your CPU is more than enough for your current usage.
lalawhee
Thanks for the advice!
Any recommendation which stores i can check out in SLS for a quick fix?
5star_pundit
My water cooling project
Watercooling Components:
AMD EK-Supremacy EVO , EK-FC1080 GTX TF6, EK-FC1080 GTX TF6 Backplate, EK-XTOP Revo D5 Pump, EK-CoolstreamPE 240 low profile radiators). EK reservoir + some a mixture of Bitspower and EK fittings.
kechiki
Hello everyone, thinking of getting a new rig. Used for gaming (but I game less than 5 hours a week now). Mostly play hearthstone and maybe some pubg. Currently using a 4k 28" Samsung monitor. Budget is $1k - $1.5k.
CPU: Ryzen 1500
Mobo: Asrock AB350M Pro4
RAM: G.Skill Ripjaws 2400 MHZ 2x4gb
GPU: GTX 1060 6gb
SSD: OCZ 240gb Sata3 TL-100 SSD
HDD: WD Blue 1TB 7200 rpm
PSU: Seasonic M12II 620W
Casing: ??
OS: Windows 10
Thanks!
Casper83
Wah... I feel damn old coming out of the darkness... Thinking of upgrading my trusty old i7...
With a budget of $1k, any kind soul can recommend something?
Would like to keep my casing and PSU if possible. hahahaha!
GOMlxA1
Hi everyone
i am thinking of building a gaming pc with a budget of about 1.5k~1.7k is now a good time to build or should i wait for any upcoming releases of parts?
sannoh
hi everyone, i would need a recommendation for a system build for gaming using a small tower case. Budget is around 1k. price would include OS. Needs WIFI card and bluetooth card as well. Price list preferably from PC themesthanks guys!
boshnel
Hey guys I'm planning to buy a new gaming PC and I would like to have some feedback of the build that I've listed here:
CPU: Intel - Core i7-6700K 4.0GHz Quad-Core Processor
Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: MSI - Z270 GAMING PRO CARBON ATX LGA1151 Motherboard
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Video card: MSI - GeForce GTX 1080 Ti 11GB GAMING X Video Card
Case: NZXT - S340 (Black) ATX Mid Tower Case
Power supply: Corsair - RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply
OS: Windows 10 Home
Case Fan: Cooler Master - MasterFan Pro 120 Air Balance RGB 42.7 CFM 120mm Fan
-Synchronicity-
Makes more sense to get a i7 8700k and z370 motherboard. Pay a little more for 2 extra cores and 4 more threads. For cooler, would recommend a cryorig h7 over evo 212.
No ssd? Highly recommended to add one.
Shearer1
Hi
Thinking of:
MOBO: ?
RAM: ?
Casing: ?
Rocking a SoundblasterX Katana currently
Considering 8700K + Asrock Taichi
1) What's the best ram to pair with the above? Strongly considering Gskill Trident Z
2) Are there 3200mhz CL14 ddr4 in the local market? Only see it online usually
4) Any practical different between CL14 and CL16, and frequencies higher than 3200Mhz?
