hoot some pc components from amazon now undecided whether I should water cool or not :
AMD Ryzen 7 1700X
MSI B350 Tomahawk Arctic
MSI Nvidia GTX1080 Gaming X Edition
Adata xpg spectrix d40 2400mhz 2x8gb
Sharp 32" living room TV
Samsung 950 Pro 512gb + WD Black NVMe 512Gb
be Quiet Dark Base Pro 900
Enermax Platimax DF Platinum 1200w
Edifier S1000db
Windows 10
why reccomend a ryzen over an intel for a gaming pc when they clearly perform worse in tests all over the internet.
Hi
Upgrading my PC from Intel i7-4771k ~2014, DDR3 16 gig.
Keeping my EVGA GTX 1080 FTW and ASUS PG279Q Monitor, Corsair H100i Cooler, and RM850 PSU
Thinking of:
SSD: Samsung 960 Pro M.2 512 gb
CPU: 7700K or wait for Coffee Lake
MOBO: ?
RAM: ?
Casing: ?
Speakers (Optional but pref good quality at decent price, say 1-200)
Assuming budget is okay but not too out of whack. Any suggestions?
but tbh ur pc is still quite capable of handling current games, and if u still end up wanna to upgrade, i still think u should keep waiting for kopileg.
Hi All
Looking to upgrade my current rig:
CPU: Intel Core i7-4790
MB: ASRock B85M Pro4
RAM: Kingston PC1600 DDR3 8GB X2
GPU: Zotac GTX 960 2GB Twin Fan OC
SSD: Samsung SSD 850 EVO 250GB
HDD: Seagate 3.5" 4TB SATA3 HDD
ODD: Samsung 24X CD/DVD Writer
PSU: Seasonic S12G 450W [80 Plus Gold]
Looking to upgrade also because of a persistent problem:
My desktop keeps restarting on it's own.
Sometimes it can last me quite awhile, after a half/an hour usage it will restart.
Once the restart kicks in, it will keep restarting after the log in. Its a cycle loop. log in restart, log in restart.
Only after i off it for sometime then it can last me another half/an hour again.
I also realised if i watch videos, some files will restart immediately.
I check my temperature and fan, all is fine.
Any advice anyone?
well for your system i still think that the cpu is overkill for your usage, unless u are really playing for high end gpu games do consider upgrading your gpu.
but to solve your issues, my guess will be either your mobo, psu or rams.
if your system is still under warranty, u can send it down for testing, but if its now u can consider going down to SLS to have a check. and see if mobo is it required to change or not. but please do ask if they still have haswell chipset board as your CPU is more than enough for your current usage.
Can look for nigel at lvl 2 "pc solution" sonethingThanks for the advice!
Any recommendation which stores i can check out in SLS for a quick fix?
Rocking a SoundblasterX Katana currentlyHi
Thinking of:
MOBO: ?
RAM: ?
Casing: ?
