Hi, I will be collecting my keys for my new house soon and planning to go for home automation to keep up with smart living trend. The Interior designer I may be engaging suggested KNX Home Automation by Schneider Electric. Anyone currently using this system? I was told that this solution is more for commercial building but they are entering the residential market now and price is competitive. Does anyone knows if I should go for this or should I ask for more option?
Hi, anyone here tried installing aeotec nano switch to their storage heater?
Or anyother zwave relay? Do you use a proxy for it? a 10 amp z wave switch can use it for 1500W de storage heater ma?
Seems lik a USA brand 'broadlink', looks cool.
But think doesnt support all types of templates too wit Alexa yet. Hope Broadlink and Bond can work on dat.
Bro
Broadlink is Tiong brand
Sorry guys I bought Alexa 1st gen last time, downloaded the app from US AppStore cos sg AppStore don't have.
It's been a couple of years now I'm just wondering if Alexa has any updates on it's app? I can't really switch to US AppStore now to check...
How to connect the tv, aircon and wall lights ?
Hi there, u planning or are already using wat devices?![]()
Planning. Planning to get harmony, echo dot2.
How to pair the lights and the aircon in all the different rooms?
I dun have Harmony, but i tink it is using IR and Wifi to control compartible certain big brands devices e.g like Philips Hue bulbs.
lookin at it, lets say u using philips hue bulbs, part 1 u should be able to control it via harmony, once this is achieved then come the part 2 of asking echo dot(alexa) to control ur harmony.
as for aircon, tink aircon remote is IR therefore u probably may 'control' only the aircon which the harmony is residing at (e.g living room), shld be sumthing lik that.
if u r using broadlink rm pro, then i can share with u more in details as im more familiar with that.![]()
Can share on broadlink rm pro? I am open. Thinking whether to buy Google mini or Echo dot as well. Which is better?
I only use Echo Dot (Alexa) before, guess i pretty much like it , for comparison with Google Mini mayb u can refer to this article ( digitaltrends.com/home/google-home-mini-vs-amazon-echo-dot/ ).
Broadlink RM pro (relatively cheap) right now can be controlled with 2 apps, e-remote and the newer IHC. Only IHC is directly compartible with Alexa BUT only the 'TV remote' template is recgonised by Alexa as of now, so you need to do some 'tweaks/hacks' to make it work with Alexa. Videos can be found on youtube such as ( youtube.com/watch?v=6qGGW8hcgOA ) Besides this, i think RM pro is quite value for it's price, as it is IR + RF (433/315mhz).
Generally TV remote, cablebox remote, ceiling fan remote, aircon remote can be controlled using the RM pro. (all needs to be configured on the app as 'TV template' as mentioned earlier)
After which, use Alexa to discover the devices and then you can use the voice command to control.
for me, i oso bought some brandless RF sockets which uses 433mhz remote, therefore im able to use rm pro to control the sockets too. The sockets i used on wall switch controlling lik bedlamps, floor lamps, etc.
currently things i control using Alexa are, 2 rooms ceiling fans (speed & light), bedside lamps, floor lamp, TV remote, cablebox remote. Thinkin of adding Alexa to my bedroom so can do the pairing of group play music, stream from international channels from TuneIn. And also mayb in future change my wall light switch to broadlink TC2 switches so can use rm pro control too.
Hmmm.. Not sure what else u want to know on rm pro. Hope this helps!![]()
can share or gpgt your brandless RF sockets?
interested to get as well if the rf can be decoded
Sounds good! I am thinking of having a Harmony for my living room (tv, aircon, etc) and rm pro for my bedroom (just aircon) and pair the harmony and rm pro to my Echo dot. Does this work?
Hmm.m.. from my understanding, i don't think there is any issue with ur planned setup, as long the relevant devices (harmony & RM pro) are linked to their respective controlled devices.
u just need to enable the Echo Dot skills for broadlink &harmony and shld be able to give voice command as per planned.![]()
