DVB TV Tuner Thread II [consolidated]
PoloBoiBoi
Mod:
This thread is for all discussion on TV tuners add ons via USB or other means.
For reception and other issues, please use the reception thread and for general discussions, use the DTV thread.
Singapore: plans to complete the switchover to digital broadcasting in line with ASEAN's commitment to switchover to digital broadcasting between 2015 and 2020. When switchover is completed, analogue signals will have been phased out and all of MediaCorp’s free-to-air TV channels will be broadcast fully in digital.
Anyone using DVBviewer on Mygica T230? Which version is stable? And are you able to tune if Tuner Type set to cable?
i using T230C though, with DVBViewer 4.9.5
i can tune with cable settings using QAM256
Kiwi8
Deluxe Member
Housekeeping also need to copy over the stuff like frequency list leh. :o
albertlee
Hmm, my TV stick only state "T230" without the "C".
So far, any version above v5.3.0 doesn't really work well on my system. Will give the version you mentioned a try. Tks.
cybertech
Does anyone know why Ch8 ChU HD not showing english subtitles when Ch8 ChU Analogue will show the eng subtitles? Is on the same USB TV tuner card TBS 5281 DUAL DVBC BDA TUNERS using DVB Dream software. Check everything but just could not figure out which settings problem.
Channel 8 HD with no english subtitles
Channel 8 Analogue with english subtitles
Channel U HD with no english subtitles
Channel U Analogue with english subtitles
PoloBoiBoi
did you turn the subtitles on? did you switch the subtitles to english? not all programmes have subtitles
cybertech
Those screen captured I posted all same programmes and from the same software, just that for HD no english sub whereas Analogue it will show english sub. No options in DVB Dream software to set subtitles, maybe I will try other TV software like DVB Viewer.
PoloBoiBoi
kodi has it
gregory_choo
analog video's subtitle is hardcoded.
dtv's subtitle is generated by the box/tv and overlayed on video, you can choose the language. you have to do a one-time setup.
PoloBoiBoi
How u stream from kodi is it live ? Can share?
yep it's live because its from the DVB-T2 tuner
just like what batuchka said you need to install nextPVR, tune the channels then setup PVR Client addon on kodi
whoooo
Kodi needs a backend already set up and TV channels viewed frontend via Kodi loh ^^ For me backend is NPVR
Many thanks both, I thought got live link and no need the t2 tuner ....too many gadget clutter the TV area for me. Thank u
caramon
For those using dvb-c, any idea will you able to watch all the starhub channels when they have free viewing during special occasion??
gregory_choo
There are live links.
SG!TV addon from kodi official repo.
720p video, good enough.
