Oneplus 5T
ufo8mydog
i believe apps will need to load sometimes.
else, you can consider buying the karbon bumper case which i am using. but cost quite exp la, about $50 :s13:
Hmmm if the app has been loaded, it should be in the background memory. Well maybe i have perfect expectation. Still beats the G6 and s8 in terms of load and how smooth everything runs.
The sandstone case is pretty expensive too. 30$ if I remember correctly from qoo10.
I got a matte dot textured black case from nillkin. Hopefully it satisfies me.
KeYoKe
you got it right there. its a smooth phone compared to other phones out there.
yup. case is expensive, but quality aint that bad. you may look at taobao for the sandstone case, friend says he got it there for like 15-20 bucks
bawawaw
Hi guys. Haven't seen/hold OP5T yet in the wild, so will ask here. Is the screen of OP5T same as OP5? In terms of flatness. I mean, does OP5T have slight curve sides?
KeYoKe
unsure if the screen is the same for OP5T and OP5. OP5T has slight curve sides
tiancaiz
I think most new phones are slightly curved on the sides no? Even the cheapest Oppos are like that
Sent from OnePlus 5Teh using GAGT
KeYoKe
anyone updated to the official 5.0.2 OTA?
any cons so far?
Dont see any cons so far. My only complaint on oxygen launcher is no notification badge. But now there is notification dots.
Battery life still monitoring. I cleared cache after flash so first 2 to 3 charging cycles battery life not very good. Will wait for it to settle down
kenner
Battery life is good for me... Got 7 hrs SOT
stone1978
Why can’t android have the notifications same as iOS to see numbers instead of a green dot
