5.7" Nia leh.... can't qualify as a phablet these days if less than 6" lol.
Side tracked a bit
Which music player is good? Xiaomi one cmi
Sent from Xiaomi MI MAX 2 using GAGT
Not sure if this drop is permanent but if it is then it might indicate Max 3 is coming.
Side tracked a bit
Recommendation would be to use
Xposed: Amplify Pro to limit alarms & wakelocks
MyAndroidTools Pro to disable services & broadcasts
Here are some guides:
Amplify Pro: what to limit (extra careful with this, wrong setting makes phone go crazy/unusable)
https://forum.xda-developers.com/android/general/guide-0-0-hour-idle-battery-drain-stock-t2973588
https://forum.xda-developers.com/android/general/guide-extreme-battery-life-t3095884
MyAndroidToolsPro: Services & Broadcasts: what to disable
(get the Pro version, makes disabling Services & Broadcasts much easier)
https://forum.xda-developers.com/showpost.php?p=73693320&postcount=32709
https://forum.xda-developers.com/android/general/guide-android-toolspro-one-fav-apps-t3262150
https://forum.xda-developers.com/ga...hare-myandroidtools-guide-to-disable-t2869119
Best way to measure battery drainage
- Better Battery Stats Official thread (signup as beta tester & get the latest beta, it will work on Oreo)
https://forum.xda-developers.com/showthread.php?t=1179809
Another less efficient method to measure battery drainage
- Settings > Battery (look for trashbin icon at top right corner), reset the battery stats after fully charged or the results will overlap
Only the recent Jan/Feb 2018 roms have this feature to reset battery stats. You will also need the latest Device Health Services from Play Store or Jan/Feb 2018 gapps.
MIUI probably have loads of these. Worse if they have it low-level on the base firmware, where all data go to China servers.
Side tracked a bit
VLC.
10 chars.
Someone here recommended me Pulsar.
Its decent enough for me as it plays all the formats I have so far.
Sent from Nokia 8800 without using GAGT
lol zhun bo?yes pulsar...can repeat the track by hitting the back button upon dropping down the notification bar. 100mb ram usage.
Hey bro, what do you do to limit wakelocks from LINE?
MyAndroidTools Pro: sections Service, Broadcast Receiver, Content Provider
Disable anything with the word
- Analytic
- AppMeasurement
- Firebase
- GeoFence (if u use GPS or location services, keep this enabled)
- InstallReferrer or Install_Referrer
If Line fail to start, undo one by one till you find it.
Amplify Pro: Alarms, Wakelocks
Nothing from Line
You may refer to this post, or the subsequent posts.
How about crashlytics?
sourceadb shell
bmgr run
bmgr backupnow --all
Yes, that one too.
Note some services names will be changed from time to time.
Refer to XDA BetterBatterStats thread.
BTW, if using Oreo, can backup all device settings, apps data to Google Drive. Must enable backup to Google Drive.
source
To check the backup: use PC, login to Google Drive page, look under Backup. Use Phone, System > Backup
To restore: after flashing rom & gapps, 1st run Setup Wizard, Restore from Cloud
For local backup to sdcard, I use oandbackup. Can backup and restore both data and apk.
Guys, anyway to use 2 sim cards at the same time, number 1 (primary sim) number 2 (secondary sim)
But i would like to disable phone calls coming in from the secondary sim
In other words u want to use 2nd sim as data? Yes u can do by setting the 2nd sim as
Ddata and call for 1st sim.
Anyway to backup google account settings? e.g google accounts for my wife and mum on my phone so that I don't have to set them up every time on a new ROM.
I'm using Titanium Backup and TWRP nandroid but both can't do that or am I doing it wrong?
BTW, I've increased deep sleep time to 92% from 60%+.
adb shell
bmgr run
