Xiaomi Mi Max 3 - Come in!
amazingone
No headphones in box?
Xiaomi phones don't come with earphones since their first phone.. :o
Xiaomi believes this help to cut cost and thus only bundle the necessary stuff like USB cables and charger.
kelvinti
No, good riddance. Phone usually give sucky earphones anyway, waste of plastic. :s13:
True! Don't anyhow give lousy "plastic". Might as well don't give. Save the ocean! Haha.
Anyway, I'm still using my good old LG QuadBeat 2 headphone.
Nakedtoes
OTG too troublesome, pay $60+ for easy 128GB is no brainer cause I'll be using it for 2 years. :s22:
u are paying $60 for 64gb and 2 gb ram only.. to me is not worth it.. different below $50 at $40 level i will get 6gb else no way.. u will not see improvement one.. trust me i use 6gb and 4gb i know..just that background load more programs only... and infact 6gb consume more power
amazingone
Free KFC for those who attended the Mi Max 3 launch event earlier in China.. :o
Nakedtoes
Seriously ah? How did you find out?
Very easy what u can test it out yrself also.. reboot yr phone clear all memory then set maybe 3 hrs dun touch the phone see the battery drain... then now u load lots of apps in back ground then same 3hrs see the battery drain... even stupid ppl also know which one will drain more lor..;)
justln
It's $60 for 2 years, $30 per year, $2 per month. Drink 1 less bubble tea already can afford. :s22:
My Music Folder already 15+gb, current Mi Max 128GB used 104GB out of 116GB. :s13:
OTG really lor so, need to bring around additional accessory.
The 6GB draining more battery is ******* bullshiat, Android already implement doze and app standby very well. There's a reason why Clear All function is useless and does more harm than good.
First link from Google:
Will a 4GB RAM Android mobile consume more battery than a 3GB RAM mobile?
There is no general yes or no ans this . Let me explain .
technically, yes the 4GB RAM will consume more power than 3GB RAM but this difference is very small and causes no effect in practical life, but if your concern is battery life then I would suggest you to go with 4GB variant.
Now, you would why ?
See , the Apps you open they get stored in RAM,the more RAM you have the more number of apps can sustain in RAM , so the CPU has to re open those apps less number of times ,thus leading to low power consumption.
So, even though the 4GB RAM may take slightly more battery life but overall it will provide better battery life than the 3GB variant, also with better performance. Thus, suggested to go with 4GB .
virus2977
Go aliexpress see they said only china version. No play store no multi language......lol. think must wait for the globe rom come then buy.
kelvinti
For those who don't know how to flash rom or sideloading Google apps. Then, must wait for global rom then buy. :)
For those who know-how. It isn't an issue with China rom. :)
kottty
****i selling $540!!!
Sent from Xiaomi REDMI NOTE 4 using GAGT
Hailgod
china rom has chinese and english. what other language u need?
Yuripa
I prefer to backup important stuff from my phone to a thump drive. Sometimes being over reliant on phone memory isn't exactly a good thing (in case of a shi+ happens scenario).
Sent from Tokyo-3 (NERV) using GAGT
