No headphones in box?
Xiaomi phones don't come with earphones since their first phone..No headphones in box?
No, good riddance. Phone usually give sucky earphones anyway, waste of plastic.![]()
OTG too troublesome, pay $60+ for easy 128GB is no brainer cause I'll be using it for 2 years.![]()
Free KFC for those who attended the Mi Max 3 launch event earlier in China..
and infact 6gb consume more power
Seriously ah? How did you find out?
u are paying $60 for 64gb and 2 gb ram only.. to me is not worth it.. different below $50 at $40 level i will get 6gb else no way.. u will not see improvement one.. trust me i use 6gb and 4gb i know..just that background load more programs only... and infact 6gb consume more power
There is no general yes or no ans this . Let me explain .
technically, yes the 4GB RAM will consume more power than 3GB RAM but this difference is very small and causes no effect in practical life, but if your concern is battery life then I would suggest you to go with 4GB variant.
Now, you would why ?
See , the Apps you open they get stored in RAM,the more RAM you have the more number of apps can sustain in RAM , so the CPU has to re open those apps less number of times ,thus leading to low power consumption.
So, even though the 4GB RAM may take slightly more battery life but overall it will provide better battery life than the 3GB variant, also with better performance. Thus, suggested to go with 4GB .
Go aliexpress see they said only china version. No play store no multi language......lol. think must wait for the globe rom come then buy.
****i selling $540!!!Go aliexpress see they said only china version. No play store no multi language......lol. think must wait for the globe rom come then buy.
Sent from Xiaomi REDMI NOTE 4 using GAGT
I prefer to backup important stuff from my phone to a thump drive. Sometimes being over reliant on phone memory isn't exactly a good thing (in case of a shi+ happens scenario).OTG too troublesome, pay $60+ for easy 128GB is no brainer cause I'll be using it for 2 years.![]()
agreed ..some more install playstore and Google service is so easy ...china rom has chinese and english. what other language u need?
