Xiaomi Redmi 6 series
kalala
Redmi 6 Pro is a China-only phone, so there's no Global ROM.
The Global version of Redmi 6 Pro will be rebranded as Mi A2 Lite, with stock Android Oreo as it's part of Android One.
wow is this good or bad thing? so forever no global rom for redmi 6 pro? even hongkong also no have?
have u managed to flash to eu rom?
amazingone
Very likely won't have global ROM ever, Hong Kong will be launching the Mi A2 series so no hope for that either.
I don't own a Redmi 6 Pro. :o
bladez87
Actually. Mediatek chips tend to run hot. Was using Lenovo k8 note and it was cooking at 40 degrees. Going to Siam all. Mediatek chips. Why you guys choose redmi 6 over 5?
Sent from Samsung SM-J730GM using GAGT
K202020K
I think GPU wise, Adreno is a safer choice than Mali GPU. Next would be the PowerVR GPU. GPUs are equally important, besides the processor make yo.
vaio2000
u can install the playstore urself la, don't waste money to ask people install for u
most app can use that that some got problem
i have solve the GRAB issues
now is the sim card problem
Hi, May i know how to resolve the grab issue.. am stuck on it too.
Do advise me ya..
Thank u.
kalala
Do advise me ya..
Thank u.
yea @poker, can advise if you have successfully unlocked or flashed to the eu rom?
i still waiting for the 360 hours... omg.. but even after that i think i also dunno how to flash hahaha
Poker
Lol I used 1 mobile market to download grab app
And it works
I can’t flash to eu rom leh
Nwws to wait 360 hours lol
vaio2000
And it works
Hi Poker,
Just sharing on my portion regard to grab app.
Just delete the App under Redmi 6 Pro ( More Apps ) Portion, and it's will work. I suspected one of the apps, may have block it..
I had also found that the Grab app, for Hitch service, location is not being reflected correctly. Example U re at Orchard, However the app, only show your last location example in Office in East side. do u have this finding on yr set?
Thank you.
Regards
amazingone
Poker
Hi Poker,
Thank you.
Regards
yup u need to shut down the app and open again, same go's to google map
gizmo666
ngbc
FYI, [FONT=Roboto, -apple-system, BlinkMacSystemFont, "]Redmi 6 Pro just got the Anti-Rollback system added to the China ROM... :(
[/FONT]
[FONT=Roboto, -apple-system, BlinkMacSystemFont, "]http://www.miui.com/thread-17042612-1-1.html
[/FONT]
kalala
And it works
hi can check if u managed to flash to eu rom or dun intend to alr?
i waited and managed to unlock the bootloader.. but got stuck dunno how to proceed to flash eu rom.. can teach ma if u know?
