Xiaomi Mi 9 - The all-new flagship
davidwong
The phone must be an engineering sample by Samsung as otherwise the youtuber won’t be able to get it so soon and hence it’s a engineering phone that’s why Samsung took it down.
No use, there are non sponsored reviewers that bought the phone with their own money. They will not response to threat by manufacturer to take down such video that highlight the flaw.
jeff79
Teardown video. Every opening are sealed to reduce water ingression.
lance88
When will it be release in SG? Anyone thinking of hooting directly from China, if not, why?
kuma-mon
If hoot from china u will get china rom, have to flash to global rom and the steps are not that easy
Posted from PCWX using Pixel 2 XL
normalperson
China rom no Google playstore. Can flash but need to write to MI and ask to unlock, usually take 3-30 days. By then shd have global rom on phones
lance88
I am ok with China rom as long as I am able to get google play to work.
simi flash, I google around, its basically installing from mi app store and change setting. Quite easy steps.
matrix05
What is the real difference between China Rom and Global Rom? China Rom has China stores and advert app but no Google play app? Global Rom has Google Play store app. Other than apps which run on top of the OS, are they the same?
balzebub
Always have issues with notifications for apps like WhatsApp, telegram etc when on China ROM. Would always go with global ROM for Xiaomi devices.
Sent from Xiaomi MI MIX 2S using GAGT
lance88
which phone u tried have this issue?
