Need help with a Gaming Desktop
Itami_to_Jigoku
Hi All,
I would like to get some advice n help with building a gaming desktop. Doesn't have to be too high end budget is ard 1.5-1.7K including monitor. My friend previously came here 3 years back to get some advice n it work wonders for him so i would like to seek some help as well. Have zero knowledge in this field.
Games im planning to run - Hearthstone, Overwatch, HOTS, Apex Legend. Dota 2.
Things im looking out for
- a better processor (maybe I7, as i like to run multiple things at one go.)
- A stronger wireless adapter my router is slight far off from my room would like to have less choppy connections (or maybe some advice on how to solve this without pulling a long ass wire from my living room to my room.)
- A good monitor with high refresh rate (hear somthing about 144hz or something like that to run 4k maybe? looking for ard 23")
- Might need a slightly better cooling unit as my table is wall-facing.
- some advice on speakers would be great too. currently using a sonic gear speaker that has some issues whenever i accidentally tap the wire loud static sound would come out.
Thx alot for the help!!
Also if any of the experts here have advice on which shop to patronise in SLS would be great too! thx!!
Elysium87
i help ppl ask first. you wanna game at 1080p or 1440p.
your budget not enough for 4k gaming. 1440p might be hard a bit also if wanna game at 1440p cause including monitor
wait for better expert to give u advice.
Itami_to_Jigoku
did abit of google im thinking game at 1080 is fine. but like monitor with good refresh rate? maybe 4k resolution abit overkill? really suck at this, all im saying are hearsay from frens who are not in the know as well
Itami_to_Jigoku
Processor
AMD Ryzen 7 2700X with Cooler Master MasterAir MA410M TUF Gaming Edition
Mainboard
Asus ROG STRIX B450-F GAMING
Graphics Card
GeForce RTX 2060 GAMING Z 6G
Memory
G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory
Display
Acer Nitro VG271U P
Storage
Samsung M.2 860 EVO 250GB / WD BLACK HDD 1TB
Optical Storage
Steelseries RIVAL 650 / Steelseries QCK PRISM / Ducky One 2 RGB
Casing
Cooler Master MasterBox MB530P with 3in1 MasterFan MF120R ARGB
PSU
SeaSonic FOCUS Plus 750 Gold
Audio
Logitech Z906 / Razer Nari
OS
Windows 10 Pro Edition
the thing beside ur post is that your suggestions? any price list to based on like whats the market rate? just wanna check
nmemonic
just built a rig but personal opinion i think for not too high end the 2700x is overkill. i would think drop to a 2600 saves a horde of cash to put elsewhere without much loss.
For storage, a lot of guys are now snapping up the adata sx8200 m.2 nvme drive (500gb) bcoz its cheaper compared to competitors but still good performance.
well thats just based on my personal opinion after doing some homework these past weeks. prior to this i also have lost touch for many years.
Also, i think your 750w psu is alittle overkill. 550w to 600w shold be ok. 650w should be provision enough.
Elysium87
Processor
Mainboard
Graphics Card
Memory
Display
Acer Nitro VG271U P
Storage
Optical Storage
Casing
PSU
Audio
OS
That's my own PC. My CPU cost about 2k, so over your budget.
Wait for better expert to give u advice.
Best is to go Ryzen as it's more budget friendly compare to Intel.
narkizy
Either the 2600 or 2600x is more than sufficient for normal multitasking and gaming. 2700x is quite overkill. Rather you save the money and use it on getting a 2070 instead of 2060 since you're more towards gaming
dgenex
With regard to your choppy internet connection, for those games more or less you just need a stable connection, doesn't have to be blazing fast.
For this, can take a look at getting a Homeplug. (Can google if you don't know what it is)
Connection will not be as fast as connect cable directly, but good enough
Alternatively, can get a good PCIe wifi card instead, those usb one usually not so stable
Sent from Xiaomi MI A1 using GAGT
PM Checklist
CPU: Ryzen 5 2600X
MOTHERBOARD: Gigabyte B450 AORUS PRO WIFI ATX ($511)
MEMORY: CORSAIR VENGEANCE LPX 3000Mhz 16Gb -8Gbx2pcs ($184)
GPU: Palit 1660Ti 6Gb ($419)
OS HARDDISK: Gigabyte M.2 NVMe 256Gb ($78)
GAMES HARDDISK: W Digital Blue 1Tb ($55)
POWERSUPPLY: Seasonic S12II 620W Non modular ($98)
CASING: Tecware Nexus ATX case ($57)
KEYBOARD: Tecware Phantom Mechanical Keyboard 87/104 keys ($54/69)
MOUSE: Tecware Vector/Impulse/Torque Pro 3360 ($39)
MONITOR: Acer KG271C -144Hz gaming monitor ($329)
Total around $1839
prices were taken from Tradepac/Bizgram/PC Themes pricelist
If you want to trim down the cost here are the following suggestions:
1. Swap CPU from 2600x to 2600, it should save you around $70+.
2. Buy a second hand but with warranty GTX 1070 instead of 1660Ti since both have the same performance. Second hand GTX1070 with warranty is around $300, that means you save around $100+.
added note:
Motherboard selected has a built-in Wifi so no need to buy a separate Wifi card.
As for speakers, consider buying a headphone instead. Saw some Takstar Pro 82 at Lazada selling for $70.
Itami_to_Jigoku
Alright will google what a homeplug is.
CPU: Ryzen 5 2600X
Total around $1839
added note:
So for wireless surfing i have to buy another wifi card also? or is there an inbuilt one among the list? thx for the help n suggestion!! sorry about the noobness
Koenig168
For choppy wi-fi, you can either get a router with more powerful antennas or get a repeater/range extender.
I used a repeater for the master bedroom to boost the signal by 2 or 3 bars until recently when I upgraded the router.
Itami_to_Jigoku
Google-d home plug, 1 question does it work well with extension wires or it has to be wall socket for it to be stable?
Itami_to_Jigoku
the MOBO listed below has wifi on it. but don't expect it to be very good
Ohhh thats the wifi part ah.. is there any way to improve motherboard connections?
those by linksys is fine right? just a normal repeater
dgenex
Best is Wall Socket, if use extension might have interference so signal not as good. Can buy those that have slot to plug extension in one.
Basically u have a few options:
1) Mobo with built in WIFI (Mostly iTX form factor)
2) PCIe Wifi Card
3) USB Wifi Adapter
Id suggest trying 1 of these 3 options first, then if signal is not good enough, try using those Homeplug/Powerline Adapter/Wifi Extender/Wifi Repeater etc.
Personally, I'd go for a PCIe wifi card if you cant get a wired connection
