Digital TV (DVB T2) Consolidated thread VI
dexter9898
Yeah.
Now I gonna adjust my recording settings to use the channel at 570Mhz.
Kinda strange why they did that, instead of leaving the channel at 586Mhz and turning off the one at 570Mhz.
Mediacorp going to return the ch35 UHF back to IMDA
Durian Shell
Good to remove 1 channel frequency (ch35) for end-user. The best is to remove the Ch33 too. Keep ch29 and ch31 will do.
They edited the program name as:
CH5 HD --> channel 5,
CH8 HD --> Channel 8,
CH U --> Channel U, and upgrade this program from SD to HD quality
amazingone
Wonder when will they shutdown the Okto channel transmission..
Posted from PCWX using HUAWEI ALPS
5star_pundit
Today i plug in a usb2 thumbdrive to my new media tv box but it give an error message say slow speed how come ??
suuhhc
Some thumbdrive are slow, I experienced this before when doing recording. Switch to usb3 thumbdrive problem solved but I'm using Draco box.
alvint86
Hi guys I have a philips 32pht4002/98, but don't have an antenna yet... Any recommendations so that I can also receive Malaysia channels?
I'm looking at the AC ryan booster antenna, is it good.?
gregory_choo
I thought ac ryan is not in business anymore :)
Go for better brand like funke.
Funke is the top brand in dvb antenna but still no guarantee that you can receive malaysia channels. You can receive only if you live at high floor and facing JB, without blockage in between.
alvint86
Oh I was looking at the channel list on the first page, I'm staying at amk guess no chance for MY channels...
AC ryan I saw from courts on promo $49.90
amazingone
Can consider the Funke DSC250 or DSC550.
amazingone
So for the cheap philips led tv 32pht4002 I just need a funke antenna then can watch digital channel right?
Yes, just need the Funke antenna and you can watch digital channel right from your Philips TV.
Hopeful33
These two weeks, my TV (not Digital Tv) that was purchased in 2012 kept giving out loud squeaking noises. 6 months ago, iMDA personnel came to my house to install the setup box and antenna.
Does anyone know how to get rid of the loud squeaking noises? Thanks in advance.
dexter9898
Most likely TV's speaker faulty liao
suuhhc
If your TV come with usb port, play a video clip using a thumbdrive & see if the loud squeaking noises occurred or play a dvd if you've dvd player. You need to confirm is your TV speaker faulty or not before blaming the digital tv box.
LoneTraveller
Hi guys, anyone know whether new BTO master antenna is able to receive dvb t2 signals or not or do we have to use external antenna?🤣
Tks!
Krabs.
I lost channel U a couple weeks ago ...... anybody can tell me the mhz it use ???
I don't want to do full auto rescan as it might mess up my channel number settings
