Digital TV (DVB T2) Consolidated thread VI
amazingone
I lost channel U a couple weeks ago ...... anybody can tell me the mhz it use ???
I don't want to do full auto rescan as it might mess up my channel number settings
570MHz
Posted from PCWX using HUAWEI ALPS
tkl23786
My mum commented to me that Channel U has disappeared from the channel list. Did a re-scan and found Channel U again. Came to this forum and found out the cause of the disappearance was the relocation of the channel.....
:s13::s13::D
suuhhc
570000 display as CNA for me ....
still unable to get channel U
It is using the old Ch U (SD) channel now which is 570Mhz, same as CNA. If you've done full scan before and keep the Ch U (SD) channel, just switch to the SD channel.
stamina
Hi do u guys experience the lower scrolling news headlines of the Hd ChannelNewsAsia to be very blurry sometimes or is it my tv or tv setting which causes the blur?
Aaagogo
more data mining and selling... wtf
petetherock
Moderator
Moderator
Hi guys I have a philips 32pht4002/98, but don't have an antenna yet... Any recommendations so that I can also receive Malaysia channels?
I'm looking at the AC ryan booster antenna, is it good.?
Most cheap antennas will work for SG channels.
Your antenna won't be the rate limiting issue for M'sian channel reception - it's your location
Durian Shell
Please mention more detail what type of equipment you used. Is your TV built-in DVB-T2 tuner? Is your TV FHD or HD ready? Yes, you need to do video set-up at your STB if your TV is connected to STB........or call M1 hotline, they can help you...
Durian Shell
Why spend money, use (metal material) paper clip will do or use currently used antenna wire.....LOL
Marbok_Tan
Subtitles caused tv to restart. Anyone encounter this? After the 10pm ch 8 news, the subtitles for the next programme does not load and the tv restart. After restarting everything back to normal
This is the third time this week that the tv restart. Noticed that it always happens around 10.30pm after news. Mine is Toshiba DVB T2 dumb tv. So weird
stamina
Im using Samsung Qled Q7FN tv and am using digital antenna.
Krabs.
about recovering channel U
last time I hidden the SD channel , now I unhide it and hide the defunct old HD channel and got it back
Kiwi8
Deluxe Member
The old SD channel is now the HD channel.
The old HD channel is no more.
Aaagogo
questions for those using the NMS DVB-T2 box; recording requires a USB storage device.
which storage device have you guys tried?
USB stick or external H/D? and also what size is your storage media?
Thanks
Durian Shell
Thanks
Both device can work. I using very old equipment. 500GB for ext HD. 1GB for my thumb drive.
Vocana
Hello! I would like some advice because I tried to contact the issue to the company but (no one reply to me for weeks)
I'm using NMS DVB T2 given for free and trying to record the video (Seagate harddrive 1TB )
image:
cdn.discordapp.com/attachments/517309495701929996/594035811591389187/20190628_132513.jpg
I was able to record up to 100 videos till this suddenly it pops up
image:
cdn.discordapp.com/attachments/517309495701929996/594036261497471006/20190625_174130.jpg
I check the storage and it has up to 600GB free space.
The next thing I know it, the entire harddrive + video got corrupted and was unable to view. It happens before when I use a USB drive with 128GB.
I wasn't able to figure out the reason why does it have to do with the fact that I used Fat32? instead of NTFS upon formatting on tv?
Another issue I've is that my schedule time for the video (i often set them at night) often skips a day/ month on its own. I don't understand that either.
Are there any better ways I could use to record the video?
gregory_choo
image:
image:
May be those cheap $20 boxes on qoo10 can do better :)
jtjt00
image:
image:
I have used both cheap K2, Snazio and Draco setup boxes for recording. All of them has one issue or another.
1. Recorded program corrupted, unable to playback and further recording even though there is free space.
Resolution: erase all after 2 weeks recording
2. Pop up message dialog message say recording media too slow.
Resolution: use Sandisk Extreme usb3.0 thumb drive, not just any usb3.0 thumb drive
3. Skip recording on some day, no resolution for this one.
4. Scramble my channel number, got to rearrange once few months. This happened to only K2 box.
