hi peeps,
I am currently invested in IWDA. but i am curious in moneyOwl Dimensional fund advisor (DFA), is it a good way to DCA? their total charges adds up to 1.17%p.a. though (0.65 p.a. for moneyowl, 0.18 for ifast platform and 0.34% for DFA funds)
Well that’s your answer right there. You can pay 1.17% every year in fees through MoneyOwl, or 0.2% every year by buying IWDA. Which would you rather?
another question,
i have term plan, medical plan and critical illness plan. Is it wise to add on disability income plan?
You probably already have too much insurance. CI insurance is usually a bit of a ripoff.
Can we have a quick and dirty answer to the forex risks when buying equity etf question?
Sure.
“The currency that the ETF is quoted in doesn’t matter. The main thing that matters is the strength of your home currency.”
That’s it.
Hi Shiny Things, just read your book. It's a really good read and I have learned so much from it.
Thanks! Glad you enjoyed it!
So being a Singaporean and intending to retire in Singapore, my USD investments (IWDA LSE, SDIA LN, etc.) will eventually need to be converted to SGD. And this unavoidably involves forex risks.
Please pardon me if this sounds like a dumb question. I understand that forex risk cannot be avoided completely, so my question is how can I reduce this risk?
Not a dumb question at all, but the answer is easier than you think: “don’t worry about it”. As people have mentioned upthread, owning a global equity portfolio gives you huge diversification across currencies - you have exposure through those businesses to USD, EUR, JPY, etc etc etc. It’s easier to just hand wave that away and not worry about hedging.
If you own USD-denominated
bonds, like in SDIA, then you do have explicit FX risk, because you have a thing that repays a fixed amount of USD. That’s why I don’t usually recommend that Singaporean investors own non-SGD bonds; you’re taking explicit FX risk in return for not a lot of extra yield.
Hi all,
How big a factor is the liquidity of an ETF?
It’s not a huge factor. The ETFs I recommend generally have very good liquidity and active market-makers. If you go off searching for different options, then yes, you should think about liquidity, because it’ll affect how easy it is to buy into and sell out of a particular fund.
While I understand the value of IWDA, for STI ETF, due to the heavy weighting, what do you think of just owning 3 banks and 2 Reits in lieu of ES3? What other major sg stocks will you add if we did have a basket of stocks to replace?
Well, think about this. You’re arguing that instead of an ETF, you should buy a basket of stocks that correlates tightly with the STI. But if you buy the ETF, you get the same exposure, but you only have to pay one set of transaction costs instead of five; that seems like a pretty good deal to me.
But which one is most promising in terms of appreciating against SGD?
That’s... not really the sort of question we try to answer in this thread, to be honest. You’re asking “what FX trade should I make for a ten-year time horizon?”; if you’re just a regular investor, you have better things to do than try to predict FX movements.
Hi all, what is the best way to invest $50K of SRS funds? Is buying a retirement plan offered by the insurance companies a good option - e.g. single premium and put for 10 years and get a lump sum?
OK, retirement plans definitely aren’t the best option. You can do a lot better, and pay a lot less in fees.
For people who make enough money that it’s worth contributing to SRS (which isn’t everyone)... if your broker lets you buy ES3, then buying that with your SRS funds and counting that as part of your total portfolio is probably the best bet.
