Today eventually I added both RF+Wi-Fi controller to control my cove light and downlight.
Using Sonoff RF WI-FI(with CE , safe to use, good build quality), come in Handy with the RF module.
3 years back, I missed doing up the full house control .
Today, take the courage to take out downlights to insert the Wi-Fi control module, did break one spring arm of the LED light (not as easy as what were illustrated on YouTube).
Always messy to DIY after renovation is done
As I am electrically trained, product safety is always my concern. After experiment with those external Wi-Fi switch for 2 years, knowing its reliability, today slot in the Wi-Fi switch to the false ceiling.
Why Wi-Fi module is used but not those wall mount Wi-Fi switches?
-still maintain AC power flow control, when not in used, can totally isolate the power without AC standby .
- no neutral line at wall switch area, messy to pull one conceal line down, wife will not agreed to hack wall to lay cable.
I have 2 Google home, 1 mini and 1 nest hub home, 3 broadlink RM mini.
No dedicated home automation kits to integrate everything.
Only Google assistant to integrate the few link actions . If more complicated scenes are required, just use IFTTT with JavaScript control.
Main control are
- TV, fans, air-conditioning (hate warm, just need to On/off with fixed 20-22degC, open loop system is enough) and lighting.
-Afternoon-single Google assistant voice command or visual triggering through the Google nest hub
-On my TV, TV box, turn on ceiling fan with right speed. Start the default channel on the TV box.
* AC power sockets are hidden in recess compartment behind a features wall for TV /media box, sound bar, routers and network switches. Everyday repeating the job of flipping door to switch on/off of appliances are tough, all appliances going to AC off after use including routers.
*all power switches are Wi-Fi control thru a smart Power strip with 3 universal sockets and 2 USB-A power ports, switches are individually controllable through Wi-Fi.
-Going to bed, switch off all , TV box is switched off through IR shutdown then do the USB power off and DC ceiling fan to standby.
-Lightings off after I move to master bedroom .
-weekdays morning, morning rush, Google mini at bathroom run 25 minutes of class 95 FM Radio playback, so that I must finish my business within 25 minutes.
- bedside lamp light up at my wake up time, within a minute , Google mini play radio. Wash up done, light off.
-weekend, switch on sound bar, sound bar booting time is slow and will not default to On mode when AC POWER is applied , still failed to time it correctly to start Chromecast Spotify over.
All these are simple control, I don't need a complicated bridging system
Till now use up 20++ IP addresses, still no need to go zeebee, zwave kind of mesh network.
All toys are Google assistant compatible so that voice commands can be used easily.
Home automation can be done with rojak appliances without the dedicated gateway
Sent from Google PIXEL C using GAGT
