Redmi 7
K202020K
I have an odd problem with my redmi 7. After charging to 100% and unplugging,it remains at 100%. Only after I reboot do I get the correct battery level shown.anyone encountered this? Using global 10.3.1.0
Sent from Xiaomi REDMI 7 using GAGT
Are you using the included Redmi 7 charger or an incompatible charger from another maker?
Sausage
Anyone on 10.3.1 global cannot access 5g wifi networks? If the network is 5g only (not dual with 2.4g) it does not show up in my redmi 7 list of wifi networks so I cannot connect. But I have a mi max 1 that can see and connect with no problem. I suspect it is the firmware version.
GoodBetterBest
May be the SSID is not broadcast ? I don't have RM7 but I have 5G wifi which is not broadcast and I need to add manually.
For you Mi Max, you might have added manually ?
Sausage
It's broadcast because my other phones can see it
I have never added manually before
And this is for all 5g networks, I've just compared the networks my different phones can detect
carboy00
Redmi 7 does not support dual-band Wi-Fi. WiFi 802.11 b/g/n 2.4GHz only.
Posted from PCWX using Redmi 5
foxer77
where to get this cheapest on qoo10 ah ? phone dead need a replacement.
u can look at qoo10 seller newstar electronic
most of my xiaomi phone i got from them, the max 2 i on offer at $159. Not sure when will it end.
Sausage
Curious
If I have a global version can I use it in China then?
hermes76
I hotspot from my other phone but the 7A unable to see the SSID, is this same issue?
Sent from HUAWEI EVR-L29 using GAGT
Maeda_Toshiie
Curious, is there any benefit in buying from a Xiaomi store, as opposed to buying from another shop? Other shops are probably cheaper, right?
ThinkMe
Experienced random freezes and notification tone ringing non stop. Anyone too?
Posted from PCWX using Nokia 6.1 Plus
xtractor
how to make redmi note 7 pro charging only when it switch off.i cant find ways to let it charge while the phone is off.
it will automatically boot up and charge once i press the power button only for merely 1 second.
i am trying to find out whether my battery got issue coz when i plug my powerbank the power never goes up
jtdcjtdc
7A for $109.9 is it worth? Looks no much difference from regular price, didn’t know it was this affordable
https://shopee.sg/product/91295375/1926922895?smtt=0.0.9
I added a just a little bit more to that price and got the Redmi 7A with 3GB RAM. That one I bought from Qoo10, its a China model, but I am ok with it.
I feel this is the last cheap phone with a handy size of 5.5 inch 720p efficient screen, 4000maH battery, and Snapdragon 439 octa core processor. The succeeding model 8A/9A all were bigger and 8A even have less RAM.
I don't think there's any more of this around S$130 with those specs.
