Apple Watch Series 5
Coless
Just got ss44 yesterday. Is it normal that the battery dropped 20-25% in 1hr? I just realised I haven't update to the latest os. I have off most of the background refresh and very light user.. anyone faced the same problem?
manofsorrows
I wan to also. I was using the titanium naked. Si beh song.... but when i switched to the nike one... waa accessories to cover it up come in liao. Sian
Scratching of screen on aluminium version cos i plan to use it naked :s13:
Snoweagle
Current 6.0.1 still drains batt. But 20-25% an hr is too much. Even if I leave mine connected solely to cellular, an hr also drains around 10+%.
KeYoKe
https://i.imgur.com/hSnDRL6.jpg[img][/QUOTE]
Hahaha precisely lor. Thats my main concern. Buy a watch and cover it up... A bit zzz
Coless
reddevil0728
For your case, sound like there is something causing the AOD not to turn off. New watch (before setup & not pair with iphone) OK right?
Once you paired with your iphone, the AOD issue surface again.
Did you try with another iphone?
I got a feeling might be a bug in watchOS whereby certain settings set in a certain way will cause that to happen.
New watch that is not paired can’t tell, cause it will keep prompting you to pair it. So at the store when they did a swap, I first did a set up from scratch. At the shop it works fine. On the wrist AOD is on, off the wrist AOD is off.
Got home, re-set up the watch from scratch. AOD is on even if off the wrist.
Didn’t try another phone. But that may be an idea if it doesn’t get fixed. When I called Apple yesterday again, they said there are other reported instances where AOD doesn’t turn off when it is off the wrist.
AOD off when on the wrist?? In the watch app under Display & Brightness, make sure the Always On is turned on. But if you tested on the spot and the display is not on when on your wrist, should inform the staff directly.
No. AOD ON when on the wrist and ON when off the wrist (it should be OFF when off the wrist)
Tested at the store it works as intended. Back home when set it up as new, same issue.
sunseer
Wifi setting?
Assuming when u setup at the store not connected to wifi.
Setup at home connected to wifi automatically.
Just my 2 cents.
reddevil0728
Wifi setting?
Just my 2 cents.
But at home or at the store, both are connected to the phone, so no wifi is being used?
sunseer
By right, when you at home, both your iPhone and Apple watch will connect to wifi.
You can look at your Apple Watch control panel to verified is it connected to the wifi.
Maybe the wifi is causing your AOD wont turn off?
reddevil0728
It's connected to the phone not wifi directly.
Zakhri32
My SG alu S5 wearing a Silver chrome case, makes it look like a SS :s13:, poor mans SS
