The Galaxy Note 8 (2017 edition)
lenseview
On note 8 now. Anyone kne how to solve this?
Sent from Samsung SM-N950F using GAGT
Weird. But check if your on battery saver. Next, go device care > battery > settings. See if any system apk is on disabled mode and/or always sleeping. Remove it.
Better dont turn on the auto disable app.
Teo Ming Ern
Anyone has this issue? I popped in my new TPG SIM into SIM 2 slot and my Starhub SIM in slot 1 signal dropped like crazy...
Teo Ming Ern
I removed the TPG SIM and restarted the phone... everything is ok now... will try again dual SIM when I go to Malaysia...
Igene
Anyone encounter slow response on Google Pay (SimplyGo) after the latest security update? It's like after you tap, 10 secs (or so) later then you hear the sound with card picture appear.
chongpang
Is is newer version consume more battery, my note8 nowadays suddenly gets hot out of no reason. :s11:
Jurong640
dont think so. I'm guessing is maybe due to new android update is more battery consuming for older phones.
I guess so, it has to be the new update. I factory reset back in August. Everything seems fine. But after the update, it's worst. Mine was first batch, pre-order from telco set.
harky
The dual SIM for data plan,
If I go oversea, I just need to switch the data to the one @ the top bar?
noMercy
Does any of you know where to fix motherboard issues apart from Samsung Service Centre?
I did an update on Tues and then all sensor stopped working. Tried to find for solution online such as to delete cache partition also didn't work for my case.
Went to service centre and was advised that is the problem of my motherboard. Repair cost would be $6xx 🤦*
lenseview
Try factory reset first.
lenseview
I may give this a try after backing up my stuffs. But just curious how will factory reset solve a hardware issue? I've seen people suggesting factory reset elsewhere too.
Might be the update mess up. Factory reset to see if it can be solved.
Can try going in to service mode using *#0*#
Choose sensors to see if the sensors are working.
