M1 RT-AC2600 Router
uncle_josh
What's the point of wifi having long range, but your device cannot reach the router ?
You should consider placement of the router , which is paramount.
Where router can reach the clients and clients can reach the router !!!
bodohboy
Hi bros, I am currently looking at buying this router from people who just recontract and not planning to use it.
For me I am on Starhub Fibre using the Linksys EA8100 bundled with my 1Gpbs plan. The only reason why I am looking to get the Asus RT-AC2600 is to be able to run ExpressVPN through OpenVPN. Will this be better or should I get the RT-AC68U instead as it comes with dedicated ExpressVpn firmware.
Anyone tried this before? Any feedback? Will be first time I am trying to run a VPN router.
xonix
That's all it says on the specification...
External antenna x 3
Internal antenna x 1
Chrisxie85
Anyone have issues connecting this AC2600 to WAN? I get this error "ISP's DHCP did not function properly" I tried on my AC-66U the internet was fine. :(
bloodyshot
appreciate if anyone can do a test on singtel fibre.
Yes i have bought one on carousell. Tested 100% able to work with SingTel. Whatsapp voice call all not issues.
Chrisxie85
UPDATE: Tried switching off my ONT for 15mins and started but no use. However, I cloned my Ac66u MAC address to my ac2600 and it was able to obtain the DHCP IP address and connect to the internet.
M1 only allow 1 specific device to connect to thier ONt? My previous router didn’t have to do this~
Could my router still have issues or is just the ISP problem?
kashix
Just call them say you change router. AFAIK, m1 never lock down MAC address.
charliebrown
also encountered this problem.
just reboot both ont and router wait a while.....
it will grab an ip eventually.
sgbird
Anyone uses the AC1200+G router? The router 5Ghz SSID does not broadcast therefore invisible in the WiFI network. How to solve the issue? It is a brand new set from M1
ralliart_ray
enable broadcast of the ssid?
benedium
Hi all I got this router and it is asking me to switch to HTTPS protocol. Should I do it? Or any reason not to do it?
