- Sep 16, 2018
P.S. Anyone able to sideload Netflix on the Mi TV Global A55 set yet though? I was able to run and install Amazon Prime through Aptoide. Mi TV comes with YouTube already. If only able to run Netflix problem free, then i can get rid of the Mi Box S.![]()
If you only need 480p, it should be easy.
If you need 4k on non Netflix certified Mi TV, forget about it.
If you need 720p, maybe need some hacked Netflix apk. Not so sure.
If you need 1080p, maybe you have to wait for somebody to be able to dual boot to CoreElec (Kodi Linux distribution), I think you can forget about it on Mi TV too.
In the end, keep your Mi Box S for now unless you are okay with 480p Netflix.
Please refer to my previous reply.
If you just need 480p on Google certified Android TV OS devices, try this one.
https://youtu.be/myiH7q7wtvY
The following is using a dual boot Linux Kodi distribution CoreElec to get Netflix FHD1080p for some Android based TV boxes, I think this will not work for Mi TV, no matter it is the Patchwall OS or the official Android TV OS.
https://youtu.be/GcbfqpWICO8
So in the end, better to get a Mi.Box S or Amazon FireTV Stick 4K.
