Xiaomi Mi Max 3 - Come in!
carboy00
after using mi max 1 and 3, very hard to switch out to other phones now. for the screen and battery size. hopefully mi max 3 will not be the last model for this line.
need to look for another phone soon as the battery life seems to be dying. any recommendation?
Can the a look at Redmi Note 9S. Largest display and battery in their official lineup so far. Can match Mi Max 3 in that regard.
eip1234
Redmi Note 8 pro and note 9 pro Max matching our Max3 screen size on paper only. They are actually long and narrow!!!!!
yusoffb01
i bought a $20 original battery from aliexpress and replaced it. Very easy and now have 2 days battery life
eip1234
Solid ... You DIY? Just use the tools that came with the battery? Do you need to do soldering? Thanks.
yusoffb01
Could you SIC the video clips you saw to change the battery yourself?
pry the white front assembly from the metal casing. start from top left. may seem impossible to separate so u gotta dig it. everything held together by plastic clips
other than battery you need to buy b7000 glue from lazada
yusoffb01
how long is yr device so fast battery died?
Sent from Xiaomi MI MAX 3 using GAGT
bought from mosimosi. supposed to be new from qoo10, i suspect refurbished, but everything seemed new. however it was bootloader unlocked 🤔
after a few months battery was bloated and caused screen to pop out. so just reglue screen area and replaced battery
kottty
bought from mosimosi. supposed to be new from qoo10, i suspect refurbished, but everything seemed new. however it was bootloader unlocked �
oh.battery bloat.cos been using ard 9 months.battery still very strong
takumee
Does it has auto phone calls recording like max 3?
Seldom see phones with this feature
carboy00
Newer Xiaomi phones use Google phone dialer now without any calling recording function. Think still can restore MIUI phone app from old phone into the new phone.
Posted from PCWX using POCOPHONE F1 Rosso Red
i1magic
Yah. I really like the recording function. But I have switched to Redmi Note 8 Pro already, it doesn't have recording liao.
i1magic
Agree. Redmi Note 9 is a good replacement for Mi Max 3.
Bigger display and 5000+ mAh battery.
