Elon Jobs
- Jun 22, 2018
Do take note most shop vouchers can only use once within a limited time span.
Cancel and order again.
Thanks. Do you let the robot vacuum first,then fill the water tank and do a second run? I still have the concept of vacuum first then mopThen you should start putting the water tank and mop to do its magic work. That’s the purpose of the S5 Max. You cannot disable vacuum, so let it be.
Unless you thoroughly mop the floor, it will take a multiple mop runs before the floor can be at an acceptable level.
The cloth will smell, that normal since it is a cloth.
Actually in my definition is these robot wipe the floor instead mop to be more precise. LoL.
before that,it's very wet as previous customers complain hydra s7 aqua planning...
u want very wet right...just reboot first then start mopping...
cheat code to unlock...![]()
The roborock s6 maxV
In China is it the T7 ?
Looking at the tao bao store for spares consumables pricing
547 hooted
Do you set your robot to vacuum and mop at the same time? Or do you vacuum first then mop?
How much before 6.6?why everybody chionging during 6.6 when before that can get the same deal and no need fight for voucher? Sinkies so easily fall for marketing gimmicks
629 flash deal has been recurring quite often few weeks before 6.6 + $30 electronics voucher code that never ran out. Same for ecovacs. Only thing is now got bank voucher, which already ran out since 2am+How much before 6.6?
Sent from Samsung SM-N975F using GAGT
Well, isnt it all about vouchers and discount.
No offer or flash sale, who is going to buy at 659 or 699?
Anyways i got it at 629-50-20-12
(using DBS live up this month again have 10% cashback if hit target spending)
From what you explain, it’s probably the same current bug of Viomi V2. It’s published in Viomi facebook. They limit the high burst water discharge to 4 hours cumulative. Viomi firmware next release will fix this and also the mopping path bug.
haha before tat the boss told me bcuz i put detergent and dettol so spoilt ..he gave me a new 1..same thing happen...he gave me another water tank,same thing happen...gave me another tank again..total he gave me 3 tank and i gt total 4 water tank on hand now...
very nice boss haha...
so i just forget it...Continue to put detergent and use the cheat code to unlock.
he told me that he had checked with his software engineer side and will update the firmware on april 26.
till now still no update.
as what u mention the bug of viomi v2 is still not settle,i guess his firmware update is really using viomi side...
other than this part,hydra s7 really work well and service really good good from the merchant...![]()
Hi Spheredome, I am waiting for the delivery of the S6 max V. Can I check how do I just vacuum and not mop? Not using the app.
And which app should I use? I do have a Xiaomi air purifier at home. Would like to have an app to be able to control both devices if possible. Thank you.
