Roborock has no vacuum only mode function. Mopping is disabled by removing the mop plate, not the tank. A magnet on the mop plate that activate mopping.
When you press the start button on the vac body, it will start or stop clean.
Mihome does not have S6MV added yet, so you should start with Roborock app, to keep the firmware up, then do the needed virtual barrier and no mop zone. Set the room and vac power, wetness per room if needed. Once saved, these setting will always be there regardless start by app or button.
My wife heard from her friend that you must remove water tank else the machine will keep suckling water tank without water and it will heat up. May i know if she is correct?
