Redmi K30 Series, Pro and Ultra
davidwong
That will depends on his usage and settings, cos usually task killers comes in if the phone has a lot of apps opened in the background while leaving unused and untouched in a lock screen and off screen state. For such situation lock the app so the easiest.
But for a person who only use the WhatsApp app and very few ie no other apps open in the background or a person (like myself) who is addicted to one handphone and keep touching it and waking it we seldom will encounter such issues.
My WhatsApp is working properly on k30 pro.I didn't even need to lock app. I only enable auto start. What's your play store version and device certified?
Sent from Xiaomi MI 9 using GAGT
bridgestonelk
Even I killed/cleared all the apps, my phone still can receive WhatsApp message without opening the app or running in the background/memory.
bridgestonelk
Beefsteak
Received a small ota update 12.0.2.0 just now for K30 pro zoom edition.
changelog:
Optimization: Increased system stability
Optimization: Reduced system lag
ranmaru1987
changelog:
Dunno if it's just me.. but phone feels smoother after update..
Sent from Xiaomi REDMI K30 PRO using GAGT
bridgestonelk
I did. Poco f2 pro(global rom) is compatible with k30 pro.
It is running fine but cts failed and device is not certified as expected. Anyone successful install magisk ?
Sent from Xiaomi POCO F2 PRO using GAGT
Hardcor3Zoner
You using poco f2 rom (global)?
Im on CN rom and have to leave whatsapp in backgrd in order to be able to rcv immediately.
Probably thats the reason why u r able to do so?
bridgestonelk
Previously I was on China rom and WhatsApp working well.
What's your playstore version and device certified?
kisaki92
Hi,
Do anyone know how to get Netflix installed in the Redmi K30 5G ?
https://m.apkpure.com/netflix/com.netflix.mediaclient/download-apk-info?_gl=1*1vynyqq*_ga*YW1wLTFIbnladlYyZm1UbWJVb1VzLUttblI1OS1kU2RIZUtEWXZOaTZ5b0dNYVplZkNha3JPSjdlODFfT3NkcjlfQ1k.
Found and tried this link ! Now can watch Netflix on my redmi K30 5G Liao hahaha
davidwong
Is it HD or SD?
