Samsung Galaxy Note 20 | Note 20 Ultra
DigDub
Most welcome. I just tested on my SD HKG N20U. Starhub really no volte. I set to on already also Don have. Both m1 and singtel also have. Shld be starhub side issue already.
Ah thanks. So starhub don't have volte on SD.
DigDub
This is likely a HK/TW firmware problem?
In Feb 2020, when I bought my Note 10+ TW, I had a Starhub and M1 line. Both Starhub and M1 were successfully VOLTE enabled on both SIM card slots.
A few weeks later, there was an update that after that caused me to lose Starhub VOLTE.
Worse I also lost mobile connectivity as the APN was no longer picked up and I had to enter it manually. I had 4G connection but no VOLTE. Obviously this must be a Samsung HK/TW firmware issue that no longer provided support for Starhub VOLTE.
As the SIM card and my Starhub line was working fine when I switched back to the previous firmware.
There was no problem with M1 and I subsequently ported over to Singtel later.
I assumed that it was a firmware problem that would be eventually fixed.
Bro DigDub, was the APN auto detected for Starhub SIM? It seems that they have dropped support for Starhub inadvertently (or otherwise).
No it doesn't auto detect the apn, had to manually enter myself. I had s10e SD and got volte. So maybe firmware issue.
rabbit1
Exynos 990 struggling with under 40FPS in games while Snapdragon glides through easily with 60FPS. Snapdragon also produces better low light shots and better battery endurance!
#norealworlddifferences
ynnek
confirm that is starhub problem
I had m1 inserted into,the phone and volte is confirm working
and apn is activated.. can anyone share the apn for starhub pls?
I tried to configure it does not have default,supl.. can this be manually key?
tks
MIVEC525
Any good tempered glass that has no issues with the fingerprint scanner?
doki81
Later they say u hater...
Sent from Xiaomi M10Ultra using GAGT
doki81
tks
Normally is the service provider side need do thing...call them to have hd voice activate for u...
Aikon
tks
https://www.4gapn.com/sg/en/starhub
Just go to Settings. Connections. Mobile Networks. Access Point names. Then add.
The details are in the link above.
ynnek
thanks I tried that but the note 20 got no option for default,supl so I enter as internet and can get connection...
I did a speed test and later my internet access gone again.. than need to reset and re enter to get back access.. so weird you m1 no prob
will call starhub later to feedback
Aikon
Yes, so it seems from Note 10 plus firmware after March, the starhub volte got dropped unintentionally, I guess.
You're right because S10+ HK set, I was using starhub then and it was volte enabled as well. Only noticed it gone after the n10+ event above. Omg so it has been missing all this while?
Through S20U and N20U? I'm already on ST & M1 so never noticed.
nakazona
U can just put the apn as shwap and leave the rest as it is then save it. This works for me on my s20+ snapdragon. Although, i have the same issue as some others regarding the volte for starhub, does not have volte even after turning it on as well.
frizee
I'm using old iPad charger leh. Not the one that came in the box.
Ok bro, anyway, thanks for your feedback. I've just sold it off already. SOT is fine but... Can't tahan the slow charging rate. :o
