human_shieldz
- Sep 5, 2005
What are you guys using to edit your 8K videos?
Received my F2 Pro from Shopee Xiaomi Store and realised that my unit runs on EU ROM. Anyone else here have their F2 Pro on EU ROM as well? Very strange to me.
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
Yup the Xiaomi Singapore Global Official Store. Gotten a few phones from them before, all verified to be proper Singapore warranty sets with Global MI version ROMs.xiaomi official store?
No big issue to me, just that EU ROM updates are pushed out quite a bit slower than MI ROMs and find it odd that the warranty sets they sell are loaded with EU ROM.
Wah no bloat. I think mine should be local. Yours doesn't say Global ah.
Meanwhile, i still haven't got the firmware update, how come so long one.
Shows Global too, just that in the software version it is EU instead of MI.
Posted from PCWX using POCO F2 Pro Neon Blue
Backup your phone then if your set is warranty by xiaomi sg bring phone down to funan and ask them to flash to global rom for you
Guys just checking. For fast charging, isit must use original charger? I'm planning to get those with multiple USB ports.
Just checking cos when I use op7t charger it is just normal charge whereas using the Xiaomi one shows fast charge
Sent from My Phone using GAGT
For full 30W then yes need to use the supplied charger. I believe so long your adapter is Quick Charge 4.0+ then fast charging should work on the F2 Pro. OP7T charger won't work cause the Dash charge is OnePlus proprietary charging hence won't work with other brand phones.
Nope, the charging tech for the Dash charge is proprietary (OnePlus' own tech) even though at the same 30W and not supported by other phones, hence if you use the charger to charge other phones, it won't fast charge.But let's say the Dash charger also 30W leh? Also can't meh?
I read somewhere that for Xiaomi's phone as long as the charger has PD or QC, it will fast charge.
Thanks for the answers, so any charger with qc4 will work. What's PD?
Yup, but any QC or PD charger can charge Xiaomi phones. OnePlus Dash and Warp Charge is not QC or PD.
