- Sep 16, 2018
am i able to configure such like ONR - ASUS AX86U - Singtel TV BOX (via ASUS vlan profile setup)?
No. This will not work.
Even if you ask SingTel to bridge the ONR and it will still not work.
how can i get this work? changing onr to ont?
SingTel will not do that for you.
If you really want to get the AX86U, you can keep the SingTel router for TV. You can connect your AX86U to the other port of ONR and configure it as a router (Double NAT) or AP.
ONR - Singtel Router (room, you can disable wireless if you want) - Singtel TV Box (room)
ONR -- AX86U
cause i think my onr is having issue and later on technician will come down, maybe i can request to change onr to ont? haha.
but bro, why singtel is offering the router but it cant work with singtel tv? abit confusing...
Finally I found the cap in the SingTel 2Gbps FAQ.Yes. Because there's only 1 GPON connection back to their OLT, you're hard capped by the limits of that 1 GPON connection. Of course it's not to their benefit that they advertise this as prominantly as 1+1Gbps, so most consumer won't know. It could be in the fine prints, but I haven't went about looking for it.
Then they are limiting the uplink speed for those plans, nothing to do with hitting the theoretical limits of a single GPON connection.
I guess in their expected use case of the 1+1Gbps plan, they did not expected users to aggregate both WAN conenctions together. If the users don't aggregate the WAN connections, they will never hit above 1Gbps down and up at any one time. If the user aren't going to be hitting the hard limits of that GPON connection, I guess it's in their best interest to not talk about it to avoid "unnecessary questions" for their helpdesk/sales team?
Whereas for their 10Gbps plan, it is likely that the user have a 10GbE NIC. In that case the user would very quickly realise they are hitting the limits of SingTel's implementation of XG-PON, so I guess it's better for them to be upfront that their the XG-PON tech they implemented has an uplink limit of 2.5Gbps.
Do note I'm just speculating here, don't take it as facts.
Same for Starhub.Finally I found the cap in the SingTel 2Gbps FAQ.
Download up to 2Gbps and upload up to 1Gbps
https://forums.hardwarezone.com.sg/...band-official-thread-part-5-a-5465321-70.html
The only possibly true 2Gbps plan was probably M1 2Gbps plan (no longer offered) if the following is correct as they use XG-PON ONT for 2/5/10Gbs plan.
On the other hand, new generation of router like AX86U with dual WAN load balancing, 2.5Gbe LAN port and WiFi 6 160MHz support (usually AX5400 and above), the dual 1Gbps plans become kind of real 2Gbps plan already.
Now thinking about it, AX86U dual WAN load balancing might work with the aggregated 2Gbps plan like SingTel and Viewquest 2Gbps as well. ??
It will not work. dual wan load balancing routes via different gateways. the aggregated 2Gbps is essentially one single lan network with only one gateway.
LACP and multi WAN load-balancing will multiply effective bandwidth but each udp/tcp connection is still limited to 1Gbps. Eg, to load a webpage, there are multiple elements and each of these elements is a connection.
2Gbps through LACP and multi WAN is different from a single 2.5Gbps or 10Gbps connection.
unless your connection is used for a large number of devices. then the 2Gbps effective bandwidth make sense. Cos there are lots of connections.
for most large downloads where you want the speed to be fast like downloading ios images.. 1Gbps or 2Gbps there is no difference because that download is a single connection.
speedtest automatically switches to 4 connections (if i remember correctly) so you will see huge improvements. But this is not a real world example.
but multi wan has real world benefits if you know what you are doing as you can connmark specific devices/applications to use a specific wan and of course if your wan providers are two different telco, then you will have some sort of redundancy as well
Thanks for the insights. So aggregated 2Gbps plan will not work.
Yes SpeedTest uses up to 4 connections.
https://help.speedtest.net/hc/en-us...How-does-Speedtest-measure-my-network-speeds-
As for large file download, I think download managers or utilities (idm, aria2, qBittorrent, etc) are mostly multithread so they should gain the benefits of dual WAN load balancing as well.
I think its might work, although im lazy to test it as i took out my MIO box and kept it. 1 of the ONR port is a ONT bridge port which connect to the AX86U, which serve as a router mode than a access point. If the theory of my previous set up of using a AC86U connected to a ONT and output MIO TV from my AC86U Lan port 4 works.
pls.. this logic only applies to load balancing over connections with low bandwidth cap. for aggregation at high speeds eg 1gbps, the full 2gbps can be utilised by a single client as high bandwidth applications commonly use multithreaded download (as i explained in earlier post), which includes bittorrent and steam.It will not work. dual wan load balancing routes via different gateways. the aggregated 2Gbps is essentially one single lan network with only one gateway.
i came to this thread to find lobangs to get AX86u... but found lots of post on 2Gbps cos AX can now be faster than your 1Gbps broadband.
but do consider the following
1) when was the last time you saturate your 1Gbps WAN consistently and for prolong periods of time?
2) wifi speed is one directional. wan/lan is duplex for almost all modern gear
3) if you really have a lot of devices, it maybe better to get multiple AC AP to distribute the load instead of consolidating into one very fast AX AP
pls do your own due diligence when read AX marketing materials.
just to add on..
AX86 has faster ram(1866Mbps) and USB3.2
AX88 ram speed(1600Mbps), USB3.1
but all those specs not really critical to users. go for the best design![]()
AX is probably not the main reason but rather the 2.5Gbe port of AX86U, which is the main benefit of AX86U versus AX88U.
Also the fact it is now bundled with SingTel 1+1 Gbps gaming plan, so that triggers the interests of a few people who want to get more out of the plan.
this is because most applications will reach the limitations of single stream tcp before hitting the bandwidth cap of 1gbps due to latency. So it is also unreasonable to expect a single tcp stream to be able to reach >1gbps throughput unless the latency is already low due to ack being received less frequently. there will be virtually no difference in download speeds between 1gbps or 2gbps connections if the application isnt designed to utilise multiple tcp/udp streams unless the latency is really low eg local mirrors. even then download managers eg idm can be used to get past this
which also unfortunately mean that ax86u not available for retail channels... well.. asus's loss
the 2.5Gbe port is practically useless for most users. no 2.5gbps ONT offered by any BB in SG. if connecting to a switch. 2.5Gbps switches are rare. imho.. it's a neither here nor there. if connecting to 10Gbe switch.. then another can of worms.
the reason i was looking for ax86u is pretty lame... lol ... it takes a very small footprint.. just nice take over position of ac68u.
