Show us the symbols/ chars and numbers key layout.I would say similar...nothing so different.
Sent from Samsung SM-N9860 using GAGT
Sent from Samsung SM-N986B using GAGT
where to get the cheap SD set?
why is HKG better than KrR?
If I'm not wrong, HK set is physical dual sim where KR and US are esim+physical sim.where to get the cheap SD set?
Should have read a bit more in this thread. HK snapdragon set don't work with starhub volte.Wtf. I bought a Snapdragon HK set but still having issue with VOLTE with starhub. Called them and they told me it's overseas set so they cannot guarantee it will work for volte/5G and they also mentioned must buy with starhub then they are responsible for it. Anyone has similar issue or situation? Please advise.
Singtel and M1 is working fine, only starhub can't. Tested and u need to browse back this thread as some of the people had tested and confirmed.Only doesn't work with Starhub VOLTE? How about Singtel and M1?
Could it be it doesn't work with the local telco's VOLTE at all?
Thank you. Good to know... Considering getting a HK set
Carousell, shopee etcwhere to get HK set? My contract is ended, thinking to recontract but all SG set are Exynos right?
Go to settings - about phone. The model number should be SM-N9860.sorry noob question again, can you give example how to check if the set is HK?
If you don't mind a used less than a month hk set and with warranty, I'm willing to let go mine since I cannot have access to volte as I'm under starhub
