Ghostfreak123
- Oct 23, 2020
No lag. Are u using good quality cable and wall charger? Using inferior quality will cause that.
Wa means maybe only me. I tried to use it but damn laggy....
This is SG exynos keyboard.
Sent from Samsung SM-N986B using GAGT
Is there warranty from alpha?![]()
Finally receive my set from alpha telcom. Their packing is dam solid. Better then taobao lol! So far so good, only open up and charge and check the setting .
Manufacture date 8 october 2020 from korean , on ATJ6 build number and sep 1 2020 security patch
Sent from HUAWEI Mate 20X using GAGT
Usage after the sw update: unplugged my phone from 1pm yesterday until today morning 10:20am connected to WiFi 100% , SOT 3hour 45min and I left 50%. Currently using 120hz as well.
The battery life is so good with WiFi now
Sent from HUAWEI BLA-L29 using GAGT
regardless of snapdragon or exynos, both have pre-installed protector film??
Finally. I too experienced a good improvement in battery life after sw update. Getting about 7 hrs SOT over a 15hrs period using LTE. This is at least a 15% improvement. I'm still using 96hz
So is it ok to get a local exonos set now?
Maybe if you only use your phone to browse net or reply message. The moment you push the exynos to do more demanding task like taking video and photos or doing gps navigation, watch how the battery drop like grapes and the phone heat up like crazy. I've used both S20+ exynos and S20FE (SD865) and there is a clear diff. Even the SD set takes better photos esp with moving objects and sharper processing.
i read some users saying battery life improved alot after the most recent software update. Maybe the battery drain on load is reduced? i seldom game, but i want my phone to be able to last the day i take videos and photos. i am thinking of SN20U because of the of good photos and videos this phone can give me. HUAWEI P40 PRO, or the coming mate 40 PRO seems even better, but no GMS is really a headache
Anyway guys , can I check izzit normal for the lock screen and AOD clock style to change to default after every reboot or restart?
Once we unlock the clock will revert back to the setting that we choose.
Sent from Samsung SM-N9860 using GAGT
