Samsung Galaxy Note 20 | Note 20 Ultra
Amuroraysg
This is SG exynos keyboard.
Sent from Samsung SM-N986B using GAGT
how to switch to this keyboard? my sd version show me separate no and symbol keyboard very annoying all keys are big and doesn't show all in one page
Zinc-Oxide
Usage after the sw update: unplugged my phone from 1pm yesterday until today morning 10:20am connected to WiFi 100% , SOT 3hour 45min and I left 50%. Currently using 120hz as well.
The battery life is so good with WiFi now
DaRRenLieW
Finally receive my set from alpha telcom. Their packing is dam solid. Better then taobao lol! So far so good, only open up and charge and check the setting .
Manufacture date 8 october 2020 from korean , on ATJ6 build number and sep 1 2020 security patch
Sent from HUAWEI Mate 20X using GAGT
etoilebiscuit
Is there warranty from alpha?
Sent from HUAWEI BLA-L29 using GAGT
DuoLeap
Good to hear it! Finally n20u getting a decent battery life.
1982-1994
regardless of snapdragon or exynos, both have pre-installed protector film??
Zerobim08
Finally. I too experienced a good improvement in battery life after sw update. Getting about 7 hrs SOT over a 15hrs period using LTE. This is at least a 15% improvement. I'm still using 96hz
DaRRenLieW
Anyway guys , can I check izzit normal for the lock screen and AOD clock style to change to default after every reboot or restart?
Once we unlock the clock will revert back to the setting that we choose.
Sent from Samsung SM-N9860 using GAGT
dgkt77
So is it ok to get a local exonos set now?
plsdunbiteme
Maybe if you only use your phone to browse net or reply message. The moment you push the exynos to do more demanding task like taking video and photos or doing gps navigation, watch how the battery drop like grapes and the phone heat up like crazy. I've used both S20+ exynos and S20FE (SD865) and there is a clear diff. Even the SD set takes better photos esp with moving objects and sharper processing.
dgkt77
i read some users saying battery life improved alot after the most recent software update. Maybe the battery drain on load is reduced? i seldom game, but i want my phone to be able to last the day i take videos and photos. i am thinking of SN20U because of the of good photos and videos this phone can give me. HUAWEI P40 PRO, or the coming mate 40 PRO seems even better, but no GMS is really a headache
Zantesuken
U can also consider mi 10 ultra.
DaRRenLieW
Any user can confirm this ! Thanks
plsdunbiteme
I think unlikely to have significant improvements as it's a hardware issue. No amount of software updates can bypass the poorly designed CPU cores of it Exynos 990. From my experience with S20+, the updates did help a bit for light use and standby drain, but it all falls apart the moment I push it a little bit. Not even gaming, but regular activities like hiking with gps and taking photos and videos along the way, the phone struggles. We're talking 50-60% battery drain in 2hrs, with phone constantly at 42-45 degrees.
Sure, it's not unusable but I don't think you'll feel satisfied with such a sub par experience on a $1000++ phone. You'll be better served importing the SD variant (if you willing to risk warranty) or just get the S20FE
rabbit1
I switched to the Note 20 Ultra because my contract is up and I can tell you, it runs warm when doing simple tasks like surfing the net and battery life is pathetic. It cannot last one whole day if outside. The variable refresh rate is fake. It just toggles between 48, 60, 120 Hz. In fact, the VRR doesn't even work if the environment isn't bright enough which is kinda of joke. The camera also takes very poor close up photos.
