Samsung Galaxy Note 20 | Note 20 Ultra
DigDub
Those using HK set, are you guys able to boot into recovery mode (by pressing volume up and power button) when turning on the phone after the 1st November patch?
Mine dont seem to be working anymore.
Also, do you all have any issues with your wifi connectivity? I keep getting disconnected on 2.4ghz band. Need to go to settings-connections-wifi then it will connect again. There is no disconnections on the 5Ghz band. My other devices on the 2.4ghz band also does not disconnect at all.
Since a few updates ago cannot already. Have to computer and usb cable and use adb to boot into recovery mode.
My wifi is 2.4ghz, no issues.
ltrinityl
Thanks for the reply. Mind asking how to enter into recovery mode using cable and pc? After you post, i read that it's the same method using vol up and power button just that need to use cable and pc?
DaRRenLieW
I am curious guys. Anyone use the find my mobile app and also enable offline finding ? Not sure will it drain any battery consumption
Sent from Note 20 Ultra Snapdragon™ using GAGT
DigDub
Need to download the adb software. Then use "adb reboot recovery" command and the phone will reboot into recovery mode. Tbh, I seldom go into recovery mode already unless got problems.
micshang
adb software is platform tool?
sstimo
Letting go a 1 mth old Samaung Note 20 Ultra HK snapdragon 865+ set. Its black. Any taker pm me please. Cheers
ltrinityl
I just tried plugging in cable from computer to phone and press the volume up and power button can enter recovery mode already. No need ADB to boot into recovery mode.
But nevertheless, thanks for the help :s12::s12:
Shawnhjm2012
Guys using N20 Ultra, other then the supplied type c earphones & 3rd party bluetooth earbuds, what other accessories u guys r using together to support usage of normal earphones.
DaRRenLieW
November security patch is here!
DigDub
Just tried this method and it works also.
