DigDub
- May 21, 2002
Since a few updates ago cannot already. Have to computer and usb cable and use adb to boot into recovery mode.Those using HK set, are you guys able to boot into recovery mode (by pressing volume up and power button) when turning on the phone after the 1st November patch?
Mine dont seem to be working anymore.
Also, do you all have any issues with your wifi connectivity? I keep getting disconnected on 2.4ghz band. Need to go to settings-connections-wifi then it will connect again. There is no disconnections on the 5Ghz band. My other devices on the 2.4ghz band also does not disconnect at all.
My wifi is 2.4ghz, no issues.
