Samsung Galaxy Note 20 | Note 20 Ultra
davidwong
Actually what will be your usage scenarios.
If you are using it for gaming or using it to edit and export long video clip to YouTube then yes SD better. Or any use case that uses intensive cpu or gpu.
But if you are only using it for social media and content consumption or just social media taking photo and video, there is not much performance difference. Though so may say battery slightly lesser (after recent patch) comparing to SD but that’s is only slight not significant.
But that been said N20U (both SD / Enoxy) version battery life not that great.
As for photos taken some felt that SD photos better but YouTube had shown there is no noticeable difference in blind test plus if you are sharing over social media the compression algorithm totally mask whatever image advantage (if there is any).
So don’t buy base in SoC decision buy it base on use case.
Lastly overseas export set forth N20 seems to have country code / area code issue which requires workaround but no such issue with local set.
5G (though no use now) also is ok with local set and spotty with export set.
That's my pain. Huawei no andriod. Biggest problem.
It's either n20u or pro max.
N20u seems to be getting alot of bad reviews due to soc here.
lcheowl
if you are not hogging to handphone for long hour, or if you are a desk-bound, the battery performance will not affect you much.
The one that impact the most is people who don't drive and work outfield.
They need to carry a big power bank to ensure their laptop and mobile phone can last them throughout the day.
gtohii
Want to sell off my note 20 ultra 12+256 HK SD version, anyone interested pm me ! 9.9/10 conditions, come with the box plus all accessories unused!
Zinc-Oxide
U are right there. If working from home like me the battery life is fine for me but not so for people who travel a lot with the phone.
tjkjean
Wanted to get HK N20U.
See that there's issue connecting to 5G with HK N20U. Is this correct?
Or there's no issue connecting HK N20U with 5G in Singapore?
lcheowl
No point of choosing a phone just due to 5G, you will be disappointed with the download speed and also it drain battery currently.
Need to wait at least 1 or 2 more years for 5g to be fully deploy in the whole island to see the improvement in the speed.
Shawnhjm2012
Agreed.. n regret the change. I toggle back to 4G & run phone at reduced battery rate to at least last 3/4 of day
teoph04
Hi guys, may i check if this phone comes with a free casing?
Posted from PCWX using SM-N986B
micshang
Hi all, I have a Note 20 Ultra casing to give away for free. It's a hard silicon clear case. Condition 9.5/10 (-0.5 for used condition).
PM me to arrange to pick up. Cheers :):s13::D
boaboy
Manage to do a photo comparison of note 20 ultra & ip12promax
davidwong
Thanks bro exactly what my sentiments abs said in my previous reply to that bro, but there is still this forever qualms by bro of Enoxy vs SD other than battery life.
unless you compare side by side, else doing a blind test, most of us cannot tell the difference.
zirdaj
Hi. For those people with SD HK version, any of you able to use VoLTE? I want to know which telco able to. I'm on Starhub and my export set's VoLTE doesn't work, which hinders my work as I always use my phone hotspot and can't afford losing my internet connection whenever there is a phone call.
Thanks.
DaRRenLieW
Thanks.
M1 , VoLte work flawlessly since Day 1
Sent from Note 20 Ultra Snapdragon™ using GAGT
DigDub
Thanks.
HK SD set don't work with starhub volte.
