Sony xperia 1 II
omelet
Looks like new system update released!
Edit: it's android 11
kimsix
900mb+ download
But took 15 mins to install.
Can't see any difference.
Maybe the notification shade can only pull half way.
Security update still 1nov
Google play still 1dec.
No 5g plan to test :o
Adam80
900mb+ download
Power to screenshot change to top of screen
Zzzzz
Sent from Sony XQ-AT52 using GAGT
kimsix
Zzzzz
Oh dear..dumb ui placement
There is a screenshot button in multi task. dont like it, keep hitting if you use gestures
I think fp reader vibrate stronger when unlock
Also the gestures navigation feels different
must swipe near the bottom to bring up multitasking.
prev version can swipe from middle portion
darkmatt
Local SG set, using Starhub. Was not working before, always drop to H during calls. Now it stays at LTE/LTE+, not sure when they secretly fixed it..:s13:
Can you double confirm if the Logo is there? Also, can test 5G? And check the 5G option in the settings.
Maybe sony wait till android 11 to fix most of the issues.
Some may even enjoy 5G/4G standby in supported networks.
http://www.xperiablog.net/2020/12/14/android-11-update-starts-rolling-for-xperia-1-ii-58-1-a-0-921/
Waiting for HK set to be pushed..
900mb+ download
My google play also 1 Dec alr.. but still on android 10 @.@
omelet
No logo, but making phone calls stay at LTE now no longer drop to H. 5G option is still there, but I got no 5G plan to test.
darkmatt
means VoLTE is not enabled... its supposed to show no matter what..
5G gg
omelet
5G gg
I got 3 other pixel phones also no show logo but VoLTE works.
The best way to test is to make a phone call not see whether got logo lol...
If it is not working, then your signal will drop to H/3G. If it is working, it will stay at LTE/4G during phone call.
Edit: ok, did a test. I went into settings and turn off VoLTE, then made a phone call. It drops from LTE to H, then back to LTE once I ended the call. Then I turn on VoLTE again and made another call, it now stays at LTE....
This means Xperia no longer show VoLTE icon just like Pixel phones.
sky37
Using Xperia 5 II on Singtel. Still on Android 10.
Suddenly showed VoLTE logo some time last week, and stays there since then.
kimsix
thanks, tried the same and got the same results as yours.
finally volte is working! :D
but now mostly call through whatsapp :o
notch bad sony sg push out fast updates.
darkmatt
hmm.. I see.. means I can probably flash sg firmware inside.. but I now more concerned about 5G LOL
Adam80
Zzzz I bought 5g booster on m1,5g is not supported
On the bright side I got 40+gb to spam every month
omelet
Interesting...seem like it was only enabled recently. I remember VoLTE still not working around 1-2 weeks ago..
rssd21
This had been the way since Xperia 1. No more showing of VoLTE icon even when there is the function.
