Air conditioning - Any recommendations please?? - Part 2
wongminmin
then, this is the timeline for r32 & r600a
tobacko
I am a current user of YOUME system 5 compressor powering 4 FCU - because Toshiba do not have a system 4 compressor. Indeed it is very quiet and cools down very quickly. I've yet to receive my first utility bill so can't comment on power efficiency for now.
the gc i asked is their backend staff.....i ask durable aircon recommendation...ME/YOUME
if i am sales, i will push for mhi for performance vs price....cause promoter no need to think much about after sales. then a lot of people think mhi=me....same company. :(
got $, anything is possible...i think $100 to $200 to replace.
if i am u, i just use furniture to cover. :o
from 1 of users i read, the compressor is extreme quiet.
if no complaints here, should be good.
tobacko
Me me me. Current user, just installed in my resale unit. Using system 5 compressor to power 1 Living and 3 bedrooms. My prior place was also Toshiba and it served me very well for over 8 years. Hence decided to stick with the brand.
Another reason I chose Youme is because they are the only brand that has R32 for system 4 for now. The only disadvantage is that they do not have a system 4 compressor, only 5. Toshiba is extremely quiet for both FCU and compressor. I am using 26k for Living. 13k for master and 10k for other 2 bedrooms.
Anyone used Toshiba Youme and have any feedback on the cooling strength & noise? Can’t seem to find much reviews online.
wongminmin
sound very energy efficiency. :s12::s12::s12:
i worry the reliability for toshiba and r32 trained technician availability in the market....so decide to get ME..... :(
wongminmin
My Daikin system 4 using R410a is phased out soon.
1 of my worries tho... but looking at r22 still in operational....it could take sometimes :D
malaysia now running r32 , very popular. dunnoe why our gahmen so slow to enforce.....:(
tobacko
I got Youme from Gaincity. Yes the technician has to be trained to install R32 because it operates at a higher pressure. Based on my past experience with Toshiba aircon, they have been very reliable. My previous model was made in Japan and its still functioning today in my other home.
For a peace of mind, I opt for the extended warranty from GC.
harky
the location is under the window... not possible to use furniture to cover le..
queerquirks
any 1 here used audiohouse air con purchase/ installation? maybe get my other appliances from them too.
their workmanship, warranty, servicing etc
micgoh
The current Youme, is it also made in Japan?
GC extended warranty is useful. Panasonic compressor motherboard failed once. Activate the extended warranty and was fully covered.
wongminmin
according to tech, they said r32 is flammable..may lead to *****
according to search engine, it said safe....erm......
for reference,
ME system 3 $284x
MXY3G28VA2 + 3 x MSXYFN10VE
SWG 22 Copper Piping
Armaflex Class 0 Insulation 1/2 inch
Keystone 3C/40
16mm Pipes
daikin system 3 $264x
MKS50TVMG + 3 x CTKS25TVMG
Keystone 3C/40
16mm Pipes
top 3 brands
1.daikin/ME
2.panasonic
it may look cheap with cashback scheme but...
-vicious cashback cycle....
-other home appliances actually priced more expensive.
erm i use table to cover......
i suggest u change it ba.....look nicer too :). need me to help u ask around?
deathscthe
I feel is their small appliance are not worth but if buy for new house washing machine, fridge all those quite worth cause can probably offset most of it and now got 10% sales
Sent from OnePlus HD1900 using GAGT
manofsorrows
Same. Using youme. Happy w it. No issues.
Also opted for extended warranty.
micgoh
Use the cashback to offset.
tobacko
No, both compressor and fan coil made in Thailand.
happy345
Is it time to buy Toshiba aircon with R32 instead of Mitsubishi StarMex R410A
I am choosing which brand to buy for System 3 to replace my current one and at the GainCity store there are choices:
Mitsubishi StarMex FN10VE $3419 (1Y)
Toshiba RAS3M40U2AVGSG $3529 -$150 capital land voucher (1Y)
The pro for Toshiba is refrigerant using R32 and by 2022 no R410A will be sold in Singapore. Anyone can advise which one is better?
happy345
Surprised why the price so different from each other
The big company like GainCity price is so high in comparison with some online seller. Eg. ME System 3 FN10, $3419 (1Y) while letscoolaircon and airconguru is $2850/$2700 with 5Y warranty.
Meaning to get 5Y for Gaincity would need pay $1000 more. I am hesitating now ...
Anyone can share the opinions on the reasons?
happy345
Should I replace the whole system because one unit not cool any more??
My current Midea System 3 has been 7 years old which is quiet and cool but a few days ago one room not cool.
$50 to call the technician check the meter (as in the photo) saying the gas is not enough; replace the valve for the room not cool and power on but the meter remain 0 (for about 1min, he say the internal part of valve stuck, trying to explain to me) then he suddenly switch off the power expecting the meter would go up to normal (but it remain 0 for 1-2min during which he saying "f**", after that the needle move very slow up).
His diagnostic is the internal part of the valve cannot move, to replace it need take the outdoor unit back for 1week with a cost about $350; he suggest replace the outdoor unit with a second hand one with $750 (6 months warranty). Plus to top up gas, $80.
After he left I felt the checkup is not sufficient, but not sure what is the best thing I can do now:
a. find another technician like Gain City (which this system bought from) to check up ($50 base)
b. replace the whole system 3 (that is why I am studying new aircon)
For any technical guru, another symptom is: when that aircon (B) is turned on together with master room (A), the indoor unit A would give out a sound like breathe out (release air?) for a few seconds every 13min.
PS. just find out cannot insert the photo, the meter has 2 plates which reading is 110 on the left and 360 on the right.
