- Sep 16, 2018
And the 229 price of one Asus can buy 2x 120 xiaomi and can do a mesh mode which unless you are wired or is sitting very close most of the time to the Asus router the average sustain wired mesh usage and speed will be higher than 1 good speedy expensive router
We were just comparing the local version with local waranty.
Local version Xiaomi AX3600 -- S$199
Local version Asus RT-AX58U or TUF-AX3000 -- S$229.
Basically local version of Xiaomi AX3600 is not worth the money.
China version of Xiaomi AX3600 -- about S$120, this is of course recommended if you are okay with no local waranty.
But in that case, I will throw in another option, China version of TUF AX3000 (no local waranty), at about RMB 599 from Taobao, and you can easily hack it into 4T4R similar to RT-AX82U.
https://forums.hardwarezone.com.sg/...-4/asus-tuf-ax3000-assassin-mode-6422415.html
One more option for local version of Linksys E8450 AX3200 at only S$158 from Hachi.Tech, 3 years local waranty. Take note Hachi.Tech description is wrong, it is not capable of Easy Mesh.
https://www.hachi.tech/biz-solution...i-6-dual-band-router-easy-mesh--0745883809646
