Samsung Galaxy Note 20 | Note 20 Ultra
deejay6901
How to change csc?
get ur imei first then look for corresponding csc code, then use this..
*#272*yourimei#
it will display a list of country csc code, pick the right one then apply
this will wipe ur phone and apply the country firmware u choose.
disclosure
i wont be responsible for any damage that might happen
ice_z80
I have been trying to use the Samsung smart switch to transfer the data but it keeps hanging when it reaches a certain percentage. I have tried using both wired and wireless but it's the same results, and it hangs usually at the images transfer.
any bros here can intro any other apps that I can use to transfer all the data from my old huawei (still with google) to my note 20 ultra?
dodongdodong
*#272*yourimei#
disclosure
Hmmmn, Does this mean export SD set can be changed to XSP to be able to connect to local 5g ......?
lcheowl
Taiwan set can use 5g in sg?
5G is not fully deploy yet, enable it will cause battery drainage and heating issue in additional to that, also having issue when you want to use tracetogether apps in shopping mall.
deejay6901
just want to share.. after changing csc and with android 11 with no bloatwares, heres my battery usage.. not bad :)
Sent from Samsung SM-N986B using GAGT
iicecube
Becareful when using export set for carrier different, I try before LG and HTC export set even its unlocked and custom ROM but when come to updates and DATA you still need their sim to be operate.
aw1007
Have been using imported set from HK for months now...received and not facing any issue with updates.
Rapufro
Do you use google pay? If so, are you still able to get Singapore offers after changing the csc?
cydutzyahoo
can anybody share exynos battery capacity?
I only get around 4 hours screen on time
exynos really jialat
sstimo
Snapdragon no good either as i tried both...somemore exynos with 5g turned on and snapdragon only with 4g as cant support 5g in sg....
