Samsung Galaxy Note 20 | Note 20 Ultra
rabbit1
can anybody share exynos battery capacity?
I only get around 4 hours screen on time
exynos really jialat
Because its using Exynos a battery drainer. Snapdragon will offer significant improvements in terms of battery endurance and system performance.
Crappie1318
Not sure why so many people are concern with the battery life. Normally I will charge either in car or drops below say 40%. Quick charge now and then
Sent from Samsung Note 20 Ultra using GAGT
rabbit1
So what if someone doesn't have a car or isn't deck bound in the office?
Zerobim08
My N20u screen went dead on Monday. Phone is working but screen totally dead. Sent in on Tue afternoon at Jurong. Screen and battery replaced. Total wait time is 1 hour.
I'm impressed with the turnaround time. Wish the firmware update is as quick as this.
Nero666
Local set ? How much is the replacement cost ?
DuoLeap
Oh no, what happened to your phone, did you drop it?
phunming
Guys, should I upgrade my Note 8 to Note 20 Ultra?
I saw M1 contract only need $400 to grab it home.
lcheowl
if you are from Note Series, you should 'cos you are unlikely to feel the impact of the poor battery performance.
phunming
Yes bro, I felt that. I am keep charging my note 8, anytime at anywhere if possible.
So except battery problem, the rest are good ?
Afraid if any quality problem...
lcheowl
as you are using N8, you will find N20u run warmer than your N8 and heavier.
The rest is a big improvement over your N8 especially the s-pen latency, the brightness.
garettos
Hi, does the TPG VoLTE work on Note 20? Or do you need to install a separate TPG dailer app?
My note 20 ultra using $10 TPG plan, good enough for me. Yes note 9 is still a very good phone and I used it daily. Sold it to a good friend of mine and also sun bian fund my note 20 ultra 🤣
