Just get Toshiba if you cannot read and have to keep asking.
2 bay,just get ds220+. Never wrong
how about 4 bay ?
how about 4 bay ?
Hi,
thinking of getting the following and get from sim lim,
anyone can advise which shop offer the best deal
1. DiskStation DS420+
2. upgrade the ram from 2 to 6 by adding 4gb additional
3. what kind of SSD to add and how much can add ?
4. Toshiba 2 x 8TB N300
any thing wrong with the above ?
should i just get the DS and ram and HDD, SSD can upgrade later ?
or just get the DS and HDD and rest if future then buy ?
What are you trying to do with the NAS that requires SSD and ram upgrade?
thought it make the transfer faster and smoother
instead of just a backup,
i want to stream movies, photo and file throughout home network via phones and tablets and other desktops and regular backup of devices,
question current NAS put in computer room which have 1 net work cable connected
if i put it in living room and connect 2 ports to network switch, would the transfer speed in the network be faster ?
finally decided to get a new nas, ds420+ and 2x8 TB Toshiba N300 tomorrow
found that dynacore sell ds420+ cheapest but their HDD is not cheapest, will ask them if they can match trade pac price for toshiba n300 7200rpm or else might have to go to 2 different place to get the items
I think your assumption will cover majority of the use cases.
Still a local NAS can be useful even if the data is less than 2TB because the desire to have a local copy. Cloud providers can be down as well and you can also accidentally delete the files.
But all in all, I guess I do not need a 4 bay NAS since the local data will not exceed 4TB in the foreseeable future, probably a two bay DS220+ will do. But still I will explore other DIY option first.
I am thinking to buy theDS920+ after reading through this forum,
about the HDD,
as the data from my computer is 4.1 TB
i am thinking to get 2 x 6 TB and set up at SHR1 and then 1 x 8 TB as standalone,
then after it is all setup, I will transfer my files from computer to the 2x 6TB and then make a copy in the 8 TB, is it okay plan ? or i am missing something ?
or the 8TB should be an external one which i periodically power up and backup from my 2 x 6TB ?
.finally bought the DS920+ and 2x 8TB, WD HGST and total damage is 1510 from Bizgram,
Tradepac no stock and need to check, went to Bizgram and less than 20mins, i am carrying my spoils home already.
cheap but no stock, is kinda of gimmick ?
but Bizgram wont budget about giving discount even i show them other place cheaper than them, but what to do,
This has always been sim lim sq. “no stock’s price”. this has been going on for decades. If I’m not wrong this bad habit is even brought onto lazada and shopee platform now.cheap but no stock, is kinda of gimmick ?
