ahsiao80
- Nov 19, 2010
Thank you all for the replies! It looks like I will get an EdgeRouter then link it to 2 Xiaomi AX6000s. What EdgeRouter should I get though? ER-4 is $282 on Lazada.
Alternatively, I can do what uncle_josh suggested and have 2 LAN points in the Living Room to link the main router back to the DB Box then to the other AP. Will have to check the cost for adding an additional LAN point in the Living Room that is linked to the DB box. Anyone have any idea? Will trunking be required or can the electrician just split the existing LAN point into 2? Also, if I went with this route, what switch should i get to be put in the DB box?
Uhmm did you just took your keys, house under reno or already moved in?
