Teo Ming Ern
- Jan 1, 2000
May I check: Does this Note 20 Ultra come with a 3.5 mm jack? Does it come with headphones in the box? Are these 3.5 mm or USB-C type?
Yes. Still can slot in Micro SD card. Just that it will take up the 2nd sim slot. Thanks.
Yup both are in fully auto modeThe Note20 Ultra exihbits less blooming in the reds and is noticeably cooler hence the pictures look more balanced... but must check if the P40 Pro+ was in the right mode or not... I'm presuming both are in fully automatic mode...
Hi to new note 20 users, are there any promos with free buds for the phone at the moment?
does anyone have any issue with the camera? when taking closeup pics of text (ie I hold too close). only one area is in focus and the sides are really blur? any settings I need to change ? if I hold further away. it becomes sharp.
Read HWZ Forum Rules!
Yeah, interested to get the phone now... but wondering if it will support both NSA & SA with mmWave & sub-6 5G or not... I'm not likely to get 5G in the next year... but like 4G, I might be forced to upgrade to the 5G network in 2 year's time and I will likely still be using the phone... and I'm on Singtel's network for now...The latest software update has been released as of May 20, 2021 for SingTel sets. Not sure if there's activated support for Standalone 5G on this update. If not, it would be in the next update.
I am using ESR one with stand. More sturdy than samsung original one i feel. Thanks.I'm currently using the UAG Civilian series. Cameras are flushed nicely and casing has a very good finished on the back too.
Thanks but it's not transparent... Not suitable... Cos I intend to buy Mystic Bronze for my wife, she wants to be able to see the phone colour through the case...I'm currently using the UAG Civilian series. Cameras are flushed nicely and casing has a very good finished on the back too.
This looks like the best option, not too expensive... Is it soft silicone material or is it hard plastic? I can't quite get that information from the ESR website...I am using ESR one with stand. More sturdy than samsung original one i feel. Thanks.
If you don't mind, you can refer to this video - . It's not silicon. It's plastic and still can bend a bit.This looks like the best option, not too expensive... Is it soft silicone material or is it hard plastic? I can't quite get that information from the ESR website...
